Home > A-Series EFI / Injection > lumenition throtle bodies
davidb
Member #: 2278
salisbury wiltshire
im looking at fitting a lumenition twin throttle body to replace my weber 45 dcoe carb hat ive got fitted to my 1275 mini turbo are lumenition throtle bodies any good . if they are ile get one as i found the firm that makes them for lumenition by http://www.jenvey.co.uk/ and they sell the alot cheaper
Won't work on an A series due to charge robbing.
This situation could change depending on how successful the MS siamese testing goes.
Your other options are SU carb or throttle body injection on an single SU type manifold..
you're running a weber 45 on a turbo'd mini? suck through?
Good point Iain, I assumed it would be blow through....
davidb
Member #: 2278
salisbury wiltshire
yes me weber 45 is being blown through
davidb
Member #: 2278
salisbury wiltshire
ah might have to go back to me modified manifold and modified su throttle body with 3 point injection then
danboy
Member #: 1381
Got any pictures of your weber blow through set up and can you please give me an indication of carb settings, particulaly what emulsion tube you have fitted.
Regards
Dave
davidb
Member #: 2278
salisbury wiltshire
ile have a look tomorrow and let u know what jet sizes im using
