| Home > Help Needed / General Tech Chat > MG Midget Strange Problem | |||||||
23rd Apr, 2008 at 11:29:53pm
I took the MG for a drive this evening over to Bath and every thing went fine until half way home when I lost all power, after coasting to the side of the road the engine died. after waiting a couple of seconds I decided to see if it would start, and it fired into life on the first turn of the key, then drove as if nothing had happened. It did this a couple of times last year and I still can't get my head round what is going on, any ideas?
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
24th Apr, 2008 at 07:51:46am
sounds like dodgy wiring (coil feed or something) IMHO that is the only thing that can 'reset' like nothing happend That sir, is not rust, it is the progressive mass reduction system
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
24th Apr, 2008 at 08:12:31am
is it stil on points and condenser? Back once again like a renegade master |
487 Posts Member #: 1495 Senior Member |
24th Apr, 2008 at 03:08:51pm
My old 998cc mini did that, was the points/condensor in the end |
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
24th Apr, 2008 at 08:38:33pm
I had a Vauxhall Nova which used to do that. It turned out to be the ignition switch, grease in it having turned into black horrible gunge. Cleaning cured it for good - the final straw had been when the wretched switch stuck and the starter motor wouldn't stop...
Geoff |
24th Apr, 2008 at 09:21:38pm
Cheers guys, I'll try a new set of points & condenser and see if it helps. Isambard Kingdom Brunel said:
24th Apr, 2008 at 09:33:56pm
Sounds like the carbs icing. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
24th Apr, 2008 at 09:56:28pm
is the carb needle valve screwing its self in and out , |
24th Apr, 2008 at 10:03:14pm
go through the usualls points condenser dizzy cap etc...... a swap of coil is called for to eliminate that first!
25th Apr, 2008 at 12:49:26am
my sunbeam alpine used to do this , it was a load of rust in the tank blocking the outlet. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
26th Apr, 2008 at 07:32:17pm
more likely ignition than fuel. 'Where does the engine go?' |
47 Posts Member #: 2547 Careful - I'm a sensitive little poppet Sydney Australia |
27th Apr, 2008 at 06:13:14am
Could be faulty ingition fuse, not making good contact. did it stall when you went over a bump? Adriano
