| Home > General Chat > Whats wrong with the theory behind this? | |||||||
24th Apr, 2008 at 09:03:44pm
http://cgi.ebay.co.uk/mini-mpi-supercharge...DVWQQrdZ1QQcmdZ
487 Posts Member #: 1495 Senior Member |
24th Apr, 2008 at 09:21:57pm
probably, but i still wouldnt mind the manifold, would plug up the injectors and stick with suck-through |
24th Apr, 2008 at 09:33:38pm
On 24th Apr, 2008 Sprocket said:
http://cgi.ebay.co.uk/mini-mpi-supercharger-inlet-manifold-with-4-injectors_W0QQitemZ330230040954QQihZ014QQcategoryZ43122QQssPageNameZWDVWQQrdZ1QQcmdZ Is it me or is this asking for touble? I think it could be made to work, but at huge time and expense. You've still got the port injection problem. Also suck through. No intercooler. Not worth the bother, in my opinion. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
24th Apr, 2008 at 09:34:53pm
So, who is goign to ask if he's used it yet??? On 17th Nov, 2014 Tom Fenton said:
24th Apr, 2008 at 09:39:25pm
He states that it needs finishing, so doubt if it has been used.
24th Apr, 2008 at 10:22:21pm
24th Apr, 2008 at 11:40:35pm
BAC look at feedback On 5th Sep, 2011 Vegard said:
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
24th Apr, 2008 at 11:57:36pm
On 24th Apr, 2008 Scruffy said:
BAC look at feedback 2 bad feedback out of 170 thats not too bad really considering we you dont no the reason it was given... i have no idea wether /how it would work as im not that smart...lol On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
24th Apr, 2008 at 11:59:44pm
On 24th Apr, 2008 Bat said:
Hi, What's the betting someone will be on here in about a week asking all sorts of questions on how to get it to work?? Cheers, Gavin :) TRUE! ![]()
![]() 6752 Posts Member #: 828 Post Whore uranus |
25th Apr, 2008 at 12:53:02am
http://cgi.ebay.co.uk/mini-mpi-supercharger-inlet-manifold-with-4-injectors_W0QQitemZ330230040954QQihZ014QQcategoryZ43122QQssPageNameZWDVWQQrdZ1QQcmdZ Is it me or is this asking for touble? I think it could be made to work, but at huge time and expense. You've still got the port injection problem. Also suck through. No intercooler. Not worth the bother, in my opinion. whats it sucking through if the fuel is going in after the blower ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
25th Apr, 2008 at 04:47:25am
TB
www.miniman.com.au
25th Apr, 2008 at 09:22:43am
http://cgi.ebay.co.uk/mini-mpi-supercharger-inlet-manifold-with-4-injectors_W0QQitemZ330230040954QQihZ014QQcategoryZ43122QQssPageNameZWDVWQQrdZ1QQcmdZ Is it me or is this asking for touble? I think it could be made to work, but at huge time and expense. You've still got the port injection problem. Also suck through. No intercooler. Not worth the bother, in my opinion. whats it sucking through if the fuel is going in after the blower ? As MM said, the throttle body is upstream of the blower - that makes it suck through. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
25th Apr, 2008 at 12:31:46pm
But isn't that how OE installations are? The ones using Eatons all do it this way. I assumed that 'suck thru' or 'blow thru' when related to SC's was more really about if it was 'wet' or 'dry' ? On 17th Nov, 2014 Tom Fenton said:
25th Apr, 2008 at 12:34:03pm
I'm sure that the OEMs have the throttle body downstream of the blower.
Edited by Paul S on 25th Apr, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
194 Posts Member #: 1296 Advanced Member Milford Haven Pembrokeshire |
25th Apr, 2008 at 12:44:19pm
On 24th Apr, 2008 TurboDave said:
So, who is goign to ask if he's used it yet??? I know this guy and the manifold, he's a member on here (and its not me). The used comment refers to the original manifold being used (standard mpi) not the supercharger/injection set up as a whole. The plan was to run staged injection and for that I suspose there is no real reason it won't work, but a lot more hardware will be required. |
25th Apr, 2008 at 03:46:24pm
but if no fuel is sucked through it ,cant an intercooler be used ?
Edited by robert on 25th Apr, 2008. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
25th Apr, 2008 at 04:46:44pm
An intercooler can be used but this set up is designed so that the charger sits on top of the manifold.
25th Apr, 2008 at 04:50:43pm
but if no fuel is sucked through it ,cant an intercooler be used ? generally suck through involves fuel passing through the compressor? I'm probably wrong, but I've always understood blow or suck to be relative to the throttle not the point of fueling. I also cannot believe that the OEMs run intercoolers at full engine vacuum at idle, but I stand to be corrected. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
25th Apr, 2008 at 05:05:14pm
If you put M90 supercharger into Ebay USA you'll find at least two examples ot where it is TB>SC>Engine - one is the Pontiac V6, the other is the Ford Thunderbird/supercoupe (which is also intercooled).
11th May, 2008 at 06:56:59pm
On 25th Apr, 2008 Paul S said:
I'm probably wrong, but I've always understood blow or suck to be relative to the throttle not the point of fueling. I also cannot believe that the OEMs run intercoolers at full engine vacuum at idle, but I stand to be corrected. I was wrong :( Stuck my head under a few blown Bini bonnets at Himley Hall today. There is no eveidence of a throttle body after the intercooler as I expected. Just the one after the air filter and a bypass. Now that surprises me as I did not expect the blower and intercooler to be running at full engine vacuum at no/part load. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
