| Home > Help Needed / General Tech Chat > Single vs twin su's on N/a application | |||||||
24th Apr, 2008 at 09:04:43pm
Is their much difference in them between perfomance.
Edited by minimole23 on 24th Apr, 2008. On 7th Oct, 2010 5haneJ said:
25th Apr, 2008 at 04:45:02am
it would be a bit better than a 1 3/4 but i would still use the hif 1 3/4 less hassel you would only lose a couple of nannas and better fuel econamy always looking for them bigger bunches of bannanas |
25th Apr, 2008 at 04:54:52pm
IMO the key factor is not the number of carbs but the manifold design. There's a shed load on twin carb manifolds in TBASE. Isambard Kingdom Brunel said:
25th Apr, 2008 at 05:40:00pm
stick with a MG manifold and SU hif 1.75" correctley callibrated
25th Apr, 2008 at 09:53:48pm
I had a 1380 with twin 1.25s about 20 years ago only about 90bhp but used to achieve 40mpg - so I always believe that whilst more difficult to set up twin carbs give better results On 5th Sep, 2011 Vegard said:
1425 Posts Member #: 690 Post Whore Norfolk |
25th Apr, 2008 at 10:19:22pm
From my experience the 1.75 was ok on say 1330 with 285 style cams, once the capacity went up and the cam duration/lift along with it twin 1.5's on steel manifold was better - but not as good for torque or power or driveability as a weber 45 on mapped ignition!
If Carling made Mini engines
25th Apr, 2008 at 10:30:54pm
Thanks all.
25th Apr, 2008 at 10:39:54pm
well a 296 is real torquey until about 2200rpm, then it drops off the face of the face of the earth until about 3200 rpm when it wakes up and comes on strong from there all the way. To stop this being a real pain daily you would need to run something like a 3.6 diff on 10's to keep the motor from needing gearchanges to keep it out of the "off cam" band. The 286 has similar characteristics at slightly lower rpm, ie drops off at 1500 ish and comes back at 2500 ish - but it doesn't produce the goods in the mid range or top end like a 296 with 1.5 rockers will.
25th Apr, 2008 at 10:48:20pm
Thanks.
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
26th Apr, 2008 at 09:13:43am
296 is pretty fierce for road use i guess
26th Apr, 2008 at 09:49:57am
26th Apr, 2008 at 01:40:12pm
I like the 285 piper - it was a nice grind in 1330. The 296 kent was road usable no problems - passed all the emmisions tests - when used with mapped ignition, ticked over at 900 rpm etc. The MED AGSP is a step up fro mthe 296, but you have to be commited to dial in mapped ignition precisely to run one on the road - no holes in teh powerband full throttle from 2000rpm all the way to 8200 and 146 baldwin nanas. Can't comment on the Russell cams as I haven't tried them but don't doubt they produce the goods as well.
27th Apr, 2008 at 01:43:31am
i used to have a 1380 with a 296 scatter on twin 1.5s (maniflow inlet)
27th Apr, 2008 at 09:40:21am
Going through one of my boxes of bits yesterday and found a twin 1 1/4" manifold, it's the big flange type so it can be opened up to take twin 1 1/2" carbs. With a bit of flowing it's not a bad manifold, but it's not as good as the tubular maniflow ones mind. Anyway it's yours if you want it. Isambard Kingdom Brunel said:
27th Apr, 2008 at 10:03:26am
Thanks very much.
27th Apr, 2008 at 10:17:01am
27th Apr, 2008 at 12:29:34pm
well I am driving a STR-930 cammed 1071 on the road... Thats even more agressive than the 296. and less cc. Its really no big issue. |
