Home > Help Needed / General Tech Chat > duplex timing gear question
mark4765
Member #: 249
do you use the tensioner on a duplex setup??? just been reading vizard's how to mofify mini and he mentions that they dont use them...whats the opinion on it???
regards mark
I personally do.... But not to actually put any tension on the chain... It's there and fitted just enough to take out the slack from the chain...
mark4765
Member #: 249
ok,cheers dave...thats how ive fitted mine
i dont bother *smiley*
SumpNut
Member #: 28
I used mine.....
Brocky
Member #: 224
Katy TEXAS
I have a duplex chain and sprockets off a 1275 A series can I fit this to my turbo motor, if so can I use the existing simplex tensioner ?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
no use a duplex one IIRC.
alex
AlexF
i just fitted the duplex gear up with no tensioner. Seems fine *smiley*
SumpNut
Member #: 28
I fitted my duplex chain with a tensioner from a standard simplex jobby, i have not got any probs!
There we go, its a case of if you want to or not *happy*
mark4765
Member #: 249
i have but not sure if i should now
*wink*
I can't rememeber
alex
Duplex tensioners? They don't exist, do they??
Tell me this
Just because the chain is a double row, why should you leave off the tentsoner?
The duplex chain is exactly the same length as the simplex, has the same amount of initial slack, therefore will rattle just the same when new.
As for duplax tensioners, no there isnt, but the simpex one will wear the same.
I would put a LITTLE tension on it
Sure i read this somewhere but cant remeber, I thought it was the yellow book. Infact it is, just checked, page 338, 3rd edition
Edited by Sprocket on 6th Jul, 2006.
I've used tensioners on Duplex setups several times. But no engine were ever delivered with a tensioner and a duplex setup.
I also used the tensioner on my setup, I have the Kent Cams silent chain kit which has a chain that comprises of "W" shaped links instead of "0" shaped links and rollers.
The only thing I am careful to do is to use a new tensioner pad on a duplex so that there is a new surface to push against the chain, rather than using one that has worn against a simplex chain previously.
As others, I don't put any load on it, just enough to take out the slight amount of slack, which on the chain setup I have is very little and appears never to have got any bigger, as I have used this kit on other engines.
