Home > General Chat > Custom HT leads
Just wandering where the best place to get custom HT is? and how much they cost? The only place I can find on line is Magnecor, and they don't have prices (which normally means expensive). Currently the British Open is fitted with a selection of Ford leads and the coil pack is located where ever the leads will let me put it, and whilst it has worked for the last year or so it's not the best of set-ups.
Hi Rob,
I use the CVH leads with the coil pack on the transfer housing. It's not too bad as the CVH leads are shorter then the OHV ones.
Rob, Magnecor as a rough guide will cost you between £50 and £70 for a set.
When you get new leads unless yours are _ucked don't evpect any difference in performanceapart but they will look nice lol. I know from some motor places you can buy seperate ones, so you could make a set up that way.
G13B
Member #: 1376
I bought a set of msd ones, for a v8 so that is 2 sets for 4 cyl, 8,5mm and ok for performance ign
they come as a complete package, leads, the plug things 90 deg and straight + schrinker tool for mounting/cutting.
//marcus
