Home > Help Needed / General Tech Chat > woobley boos guage!
timboc
Image and video hosting by TinyPic
Member #: 2043
hi guys, mite sound a random question but when my car is at idle the needle on the boos guage jumps around alot, as soon as you give it a bit of throttle it's ok, is this normal? also i have got quite bad clutch judder, its not the crank seal as this is new, i did fit a new ring gear could this of made everything out of balance?
cheers tim8-)
How smooth is your idle ? If it's very erratic it could cause the needle to jump.
What clutch plate are you running ? Have you changed this when you changed the ringear ?
timboc
Member #: 2043
yeh new plate, its a rally one, the idle is pretty smooth to be honest seems to run fine, tis a bit odd!!!
Did you just use the standard plate before ? If so, you'll find the AP Rally/Race plate a little more "aggressive".
Ric
Member #: 36
Basingstoke
i had this, you need to get a t piece with a restrictor in it to run to the gauge. Smoothed mine right out.
timboc
Member #: 2043
yeh i dont rly mind that but i think its more somthing in warped or out of balance as its wort of an actuall judder through the engine.?
timboc
Member #: 2043
timboc
Member #: 2043
cool where did you get the restrictor from mate?
Ric
Member #: 36
Basingstoke
it was part of a t piece, i had it knocking round the garage, i think it came with an autogauge boost gauge. I've only got the one, otherwise i'd pop one in the post to you.
If you drop them a mail from their website, they may send one to you. :)
A nozzle from a mig welder or a Weber carb jet should do the job *wink*
timboc
Member #: 2043
ok cheers for that i wil try the welder nozle!*tongue*,
does anyone have a good pre verto flywheel and back plate they are looking to get rid of??
I think i have a couple knocking about, i'd hate to think what postage would be though ...
timboc
Member #: 2043
yeh good point, any one got a light one??? *tongue*
