| Home > Help Needed / General Tech Chat > speedo not working since new engine! | |||||||
29th Apr, 2008 at 03:38:27pm
hi
My build thread..
29th Apr, 2008 at 04:25:25pm
Is the cable properly located in the speed drive before you tighten the retaining ring? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
29th Apr, 2008 at 04:40:49pm
Did you check the speedo drive ratios? the new engine may have a different drive ratio and that coupled with a different speedo ratio than its designed for could cause a big difference in the readings.. Edited by Turbo Tel on 29th Apr, 2008. website:- http://www.terryhunt.co.uk
29th Apr, 2008 at 05:02:14pm
Does the needle bounce a bit? When mine wasn't screwed in right the cable would slip every few turns but you can tell this because it bounces around. On 7th Nov, 2008 Nic said:
30th Apr, 2008 at 12:50:23pm
i always had a problem with my speedo not working
30th Apr, 2008 at 06:32:44pm
what put thread lock in the end of it were the cable goes??
My build thread..
30th Apr, 2008 at 09:18:56pm
no, take off that bit that the cable screws onto (3/8ths) and then pull out the shaft |
6th May, 2008 at 05:23:28pm
ok an update
My build thread..
6th May, 2008 at 07:57:04pm
