| Home > Technical Chat > hif44 pressurised | |||||||
9 Posts Member #: 2573 Junior Member |
1st May, 2008 at 06:25:36pm
Hi guys right i'm gonna kick off with my carb issues! I am using a hif44 on my renault 5 turbo and i'm having issues with on boost fueling, cruise is fine etc but around 4k when coming on boost it starts to run lean as if its not pulling the fuel hard enough. I have made an inlet plenum and there is no restrictor in it so will that be an issue?? Tried filing needles etc but still runs lean, messed around with float level and needle vaves, tried different viscosity oils in dashpot as well! I have blanked off the pipe which is next to the fuel inlet on the carb and i have also blanked off the pipe which is at an angle, think they both go into float chamber and inside of carb?
1st May, 2008 at 09:18:07pm
The restictor is essential in terms of making the carb work properly under boost, there is a really good post about it some where, I'll try and find it. Isambard Kingdom Brunel said:
1st May, 2008 at 10:35:16pm
Yeah i found that post! Really usefull information, i have made another plenum this evening and i shall give it a try tommrrow and let you know how i get on |
1st May, 2008 at 10:39:53pm
On 1st May, 2008 poshboy said:
i have made another plenum this evening and i shall give it a try tommrrow and let you know how i get on Wow, quick work. that's not really the TM spirit, you need to think about it, then mull it over, then go to that garage. Then realise it's a bit cold and there's beer in the fridge and go back in. Then basically make excuses 'til some time in mid June, before finally spending every free hour in the garage from then 'til midnight before the Mini showdown. I guess having a n R5 means you don't follow this ritual. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd May, 2008 at 08:39:18pm
Right i can now speak with authority!! If you do not use the restrictor in the plenum then it will completely lean out your on boost fueling! I have gone through numerous needles and tried lots of float levels in fact i think i have tried nearly everything!
2nd May, 2008 at 09:44:55pm
this is the law
i have made another plenum this evening and i shall give it a try tommrrow and let you know how i get on Wow, quick work. that's not really the TM spirit, you need to think about it, then mull it over, then go to that garage. Then realise it's a bit cold and there's beer in the fridge and go back in. Then basically make excuses 'til some time in mid June, before finally spending every free hour in the garage from then 'til midnight before the Mini showdown. I guess having a n R5 means you don't follow this ritual. Drives
2nd May, 2008 at 10:47:41pm
3596 Posts Member #: 655 Post Whore Northern Ireland |
2nd May, 2008 at 10:54:42pm
SU's do work extremely well when boosted....
3rd May, 2008 at 10:27:38am
Well i banked off all the choke unit as well and first of all i thought i had bunged the wrong hole in the float chamber.
22 Posts Member #: 1909 Member Cracow, PL |
3rd May, 2008 at 07:56:28pm
Yeah, it was Me On 2nd May, 2008 Bat said:
Hi, It's funny you should post this, there was someone one on here recently asking about putting an R5 carb on their A series. Cheers, Gavin :) |
4th May, 2008 at 09:42:43am
444 Posts Member #: 2885 Senior Member |
22nd Jan, 2009 at 11:07:37pm
In Graham Bells forced induction bible he speaks of each 90degree bend in charge piping results in a 1psi. drop in pressure.
23rd Jan, 2009 at 09:08:28am
That is a very good idea, mainly alowing you to run less boost at the compressor, and likely to result in running in a higher efficiency zone.
194 Posts Member #: 2873 Advanced Member Milton Keynes |
23rd Jan, 2009 at 12:47:30pm
On 2nd May, 2008 poshboy said:
Is there any mini meets in the bucks area? Hi there is a mini club in the milton keynes area, tyred and exhausted minis,http://www.tyredandexhausted.co.uk/, its a great club and fulled with great people take a look at the site, maybe join up, we meet first friday of every month, so next meet is on the 6th of feb. We are constently doing breakfast runs and also do the well known runs eg london to brighton, stamford hall etc... |
11th Feb, 2009 at 11:58:43pm
Dont mean to hijack but similar subject..
12th Feb, 2009 at 08:05:11am
Yes
12th Feb, 2009 at 06:18:49pm
The diff housing cover bolts will also fit.
, funny thing is, since that time I found like 2-3 hif44's that are turbo-ready. One of them is in great condition, but lacks needle.
