| Home > Help Needed / General Tech Chat > rattle from clutch | |||||||
271 Posts Member #: 1844 Senior Member BURNTWOOD, staffordshire |
5th May, 2008 at 06:15:18pm
hello all
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
5th May, 2008 at 06:36:43pm
release bearing maybe? Coming loose or breaking up ? |
5th May, 2008 at 06:45:40pm
I thought of that but wouldent it get worse when u depress the clutch as it is it stops all together when u press the clutch in |
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
5th May, 2008 at 10:10:03pm
Might b a lose flywheel. When the clutch is engaged the flywheel is pushed up sraight and the rattle stops. Just a guess.....
5th May, 2008 at 11:22:11pm
5th May, 2008 at 11:29:15pm
A knackered release bearing normally makes a noise when the pedal isn't pressed. Obviously check all other bolts when the covers off. Edited by Jason G on 5th May, 2008. On 19th Jan, 2010 wil_h said:
6th May, 2008 at 06:17:35am
thanks guys will have a look the weekend and let u know |
6th May, 2008 at 11:59:17am
Primary gear front bush. I had a similar rattle, it turned out that the bush was FUBAR'd on the primary gear, and it had only done 3k miles!!! Im going to order a floating bush for it.
6th May, 2008 at 12:11:06pm
My Moneys on the Release bearing. They stop rattling with the clutch in, ive had a loose flywheel and i new i had loose flywheel, the engine near shook it self to bits and it wouldnt run right. Edited by MikeRace on 6th May, 2008. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
6th May, 2008 at 12:57:10pm
idler gear thrust clearances is another possibility |
47 Posts Member #: 2547 Careful - I'm a sensitive little poppet Sydney Australia |
6th May, 2008 at 01:40:57pm
Yeah can be your drop gears rattling. I know mine rattles in neutral without clutch pressed. Nothing to worry about though. unless it sounds like its gonna fall to bits n pieces. Adriano
7th May, 2008 at 06:50:24am
if they are sc drops then they will rattle anyway when its warm always looking for them bigger bunches of bannanas |
8th May, 2008 at 06:29:09am
hello
8th May, 2008 at 08:41:11am
Can you take a picture so we can see whats goin on? Adriano
8th May, 2008 at 09:50:03am
8th May, 2008 at 10:32:56am
You mean on the end of the crank?
8th May, 2008 at 11:21:29am
On 8th May, 2008 wolfie said:
a picture of the rattle? Yeah I found the rattle!
Adriano
8th May, 2008 at 12:07:48pm
yes that's the bit number 3 I have a spare off another engine could that cause the rattle |
8th May, 2008 at 12:19:02pm
Yes big style, your lucky it didnt cause any major issues.
On 8th May, 2008 alandavies215 said:
yes that's the bit number 3 I have a spare off another engine could that cause the rattle 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
