| Home > Help Needed / General Tech Chat > Brake Lights - Wiring? | |||||||
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
6th May, 2008 at 02:10:01pm
Hello chaps,
6th May, 2008 at 02:11:50pm
yep just the two wires as long as the rest of the loom is good
6th May, 2008 at 02:15:51pm
try shorting the spades together. On 28th Aug, 2011 Kean said:
6th May, 2008 at 02:33:56pm
basically its just power on to the switch, then from the switch to the brake lights, obviously one side earthed. have you put the earth strap on in the boot for the light cluster? |
6th May, 2008 at 02:35:48pm
The rear lights work, so I guess thats a yes for the earth, Iain.
6th May, 2008 at 02:40:17pm
to be honest mate if you have the pedal switch, just use that instead and extend the wires type thing. much more reliable. |
47 Posts Member #: 2547 Careful - I'm a sensitive little poppet Sydney Australia |
6th May, 2008 at 04:13:47pm
First test with a test light the two wires going to the brake switch (hydraulic or mechanical, whatever yours is). One of the 2 should hold 12v this is the 12v feed from the fuse box, the other wire is the wire that connects to your brake light globes. So in reality, If you have a 12v feed and have temporarily touched the 2 wires together you should have 12v at the brake lights. If not then test for continuity between the switch wire and the brake lights and find the missing link! VOILA! Hope this helps. Adriano Adriano
6th May, 2008 at 08:50:23pm
Edited by Bat on 6th May, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
41 Posts Member #: 2397 Member Plymouth |
6th May, 2008 at 09:04:56pm
Did I not read somewhere you are re-shelling? Sounds as if you have two brake light switches? one hydraulic (brake line), one mechanical (pedal).
6th May, 2008 at 09:19:49pm
Can't remember what wiring loom we used, 90's one iirc |
6th May, 2008 at 09:25:41pm
You should only have the wires at the pedal then, unless you have cut and shut two looms. Sounds as if you can ignore the switch on the brake line - is there wiring at this point?
6th May, 2008 at 09:28:22pm
On 6th May, 2008 apalazz1275 said:
light globes Ah, I haven't heard anyone say light globe since I left OZ. Can you say "a cake of soap" to make me happy? On 7th Nov, 2008 Nic said:
6th May, 2008 at 11:52:18pm
Yeah Mate! Ah could ya chuck me a cake of soap! But don't drop her caus you"ll be the one picking her up ey! LOL Adriano
