| Home > Help Needed / General Tech Chat > Indicator/Hazard wiring problem | |||||||
6th May, 2008 at 03:14:36pm
Hello, having some issues with my wiring atm, currently i only have indicators working on the passenger side and the hazards dont work at all. Fitted 2 new flasher units and a new hazard switch. The indicator flasher unit clicks when you move the stalk in both directions but nothing flashes on the right. Also the inline fuse keeps blowing (brown and purple/orange wire). Any ideas i hate wiring and have gone over it all more times than i care to think about lol. Cheers |
158 Posts Member #: 551 Advanced Member Ashington W.Sussex |
6th May, 2008 at 04:47:28pm
Connect the 2 wires from the indicator flasher unit (on bulkhead) together with a paper clip. If all indicators come on solid then you know the wiring for the lights etc are ok. Concentrate on getting the indicators working properly before looking at the hazards as they are obviously linked and hazards won't work properly till you've sorted the indicators. What rated inline fuse are you using for the hazards? |
6th May, 2008 at 08:39:24pm
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
6th May, 2008 at 09:17:47pm
I agree with Bat, I had a similar problem, turned out I'd got the live wired to the earth side of the bulb holder. Doh |
6th May, 2008 at 11:21:23pm
15 amp, cheers for the replies :) |
47 Posts Member #: 2547 Careful - I'm a sensitive little poppet Sydney Australia |
7th May, 2008 at 12:16:54am
I would disconnect the wires connecting to the bulb first.
Adriano
