Home > Help Needed / General Tech Chat > Accelerator linkage on carb
minimatt
Member #: 2417
Hi everyone not sure what ive done wrong here put im putting the carb back on to my mini and the accelator linkage is fowling the inlet manifold so there isnt enough throw to open the carb the plastic gasket is still on the inlet maniflold well i think its that, and the bracket for the accelerator is the otherside between the carb and the nut which holdsit on if that makes sense i presume this is the right way round as i cant see the bracket going on before the carb as i dont see how it would seal what have i done wrong can anyone help thanks
Turbo Tel
Member #: 588
Delaware, USA
It seals because you use 3 gaskets...
I actually have a similar question..
Does the bracket "plate" go on the manifold side of the spacer or does the spacer go next to the manifold, then the bracket then the carb?
Since the rebuild its not quite as good warm starting and I was wondering if the bracket (which has a heat shield mounted to it as well) being near the carb was causing more heat to get to the carb after leaving it sit for a while..
Edited by Turbo Tel on 7th May, 2008.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Just put some pics on another post. Might help.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=169690
On 19th Jan, 2010 wil_h said:
minimatt
Member #: 2417
Thanks Milamber id forgoten to use the acclerator cable bracket which ment the though extra mill caused the throtle linkage to foul the inlet manifold
Turbo Tel
Member #: 588
Delaware, USA
OK Thanks
Thats like mine but I'm going to try it the other way anyways..
terry
