Home > 998cc > i am after putting a t2 on my 998
blister
Member #: 2590
Croydon
so far i got a fuel regulator, turbo gauge, and the t2 turbo
i need help on a few things i got a t2 from a renault and there is a whole in the acuator is that bad? i can upload picks if anyone needs it
i am after putting the turbo on a metro turbo manifold and i need a plate to change it can anyone help with where to get one i read jimster has one or makes them
Just bid the actuator and put another one on.
You can use any actuator if you make up a bracket *wink*
Ben H
Member #: 184
Melton Mowbray, Pie Country
I may have a T2 plate and the one for the exhaust too, I will have a look. Normally £10 each + postage. They are not a simple thing to fit though. There are some instructions knocking around somewhere.
http://www.twin-turbo.co.uk
blister
Member #: 2590
Croydon
this is my turbo and where the hole is also would what you are selling make for a straight exchange?
blister
Member #: 2590
Croydon
i tried upload photos and it aint letting me
blister
Member #: 2590
Croydon
Ben H
Member #: 184
I have had a look and all I can find at the moment is the adapter from the manifold to the turbo. I can't find the exhaust. I suspect that it is in my other mini that is stored miles away.
blister
Member #: 2590
Croydon
ok well is that for metro manifold to t2 turbo if so i would love one *happy*
hario
Member #: 2885
the actuator has a pressure side (connected to the plenum) and an atmospheric side (vented to atmosphere) ..via a hole. Because otherwise the diaphram would be restricted by the air contained on the other side of it..
..oviously..
*tongue*
