| Home > Help Needed / General Tech Chat > MPi Tanks | |||||||
7th May, 2008 at 09:16:49pm
Can I ask are these 7.5 gallon like the pre injection ones (1974-1990) or are these bigger (something sticks in my head about 9 gallons?)? Are they secured by a diagnal strap or something else? And finally, what sort of fuel hose/line do you use for under the car, do you need a solid line or will decent fuel grade rubber hose do (Areoquip stylee but cheaper)? On 7th Nov, 2008 Nic said:
7th May, 2008 at 09:17:51pm
Argh forgot to say thanks, where are my manners. Thanks! On 7th Nov, 2008 Nic said:
7th May, 2008 at 09:40:17pm
They are 7.5 gallon I think, secured by a diagonal strap although it is somehow slightly different although I can't remember how. I use the standard MPI fuel lines (solid) underneath as this gives a really neat job.
7th May, 2008 at 10:12:26pm
Ah I see. Looking at the MS catalog, they show a strap that is different from the diagnal one on my 5.5 gallon tank (labled 27 and 28). Maybe that is how they're strapped in?
7th May, 2008 at 10:58:48pm
8th May, 2008 at 09:06:29am
I used the original strap with no probs if that helps. |
