Home > Help Needed / General Tech Chat > different feed and return fuel line
Simon
Member #: 1865
Norwich, Norfolk
before the post whores reply with "try the search" i have and there is lots of info but not specifically to what im after.
obviously 8mm ID feed and return is bestist, but, on my old n/a setup i used 6mm ID stainless braided hose and have ample surplus of that still new that I could use for one length of the car.
So if i get some new 8mm ID and my current 6mm ID, one of each, which would I use for the feed and which for the return? its just to reduce my cost on fuel line as I have a load spare and brand spankers sitting there.
also, i previously experienced a fuel leak from the 6mm ID hose where it connected to the HIFF 44, isnt 8mm just going to increase this problem?
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
From what i can work out you want a lower pressure for return
so 8mm for return and 6mm for feed.
Correct me if im wrong
Turbodaves link explains it.
http://turbominis.co.uk/forums/index.php?p=vt&tid=4423
Edited by Jordan on 12th May, 2008.
Simon
Member #: 1865
Norwich, Norfolk
cheers jordan, i'll stick with the 6mm feed, i dont see the point in using an 8mm feed if the fuel entry point to the carb is less than that as thats the bottle neck.
i have a facet red top pump, is there a "prefered" regulator to use with that or stick with the metro turbo one? something like http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=280226245824
Edited by Simon on 13th May, 2008.
Jordan
Member #: 1392
Dont use a red top. You want a roller vane fuel pump.
Hehe i found this out.
Stupid brain!
I'd use the metro reg, I think a brand new one from MS is only £35?
redwing
Member #: 1574
Malta
Definately larger bore on return line.
Jordan
Member #: 1392
Ive gone OTT and done 10mm feed AND return.
Dunno whether itll be to big, but i guess ill have to grit my teeth and find out.
Star Mag
Member #: 375
Leicestershire
I have used 10mm on mine for a couple of years without any problems! However i am going to 8mm as im tidying my pipework up.
