| Home > Help Needed / General Tech Chat > turbo | |||||||
90 Posts Member #: 2000 Advanced Member northampton |
15th May, 2008 at 07:50:01pm
Excuse my ignorance but do all t2 turbos have the same stud pattern i.e fiesta rs turbo will be the same as a renualt 5 turbo. What i mean is if i go for a t2 turbo then does it matter which one when buying an adaptor plate to go from t3 to t2. Does that make sense? |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
15th May, 2008 at 08:32:44pm
IIRC the ford fiesta T2 has a few casting differences to the R5? I may be wrong tho!!
15th May, 2008 at 09:10:49pm
All T2s have the same stud pattern, but there other differences between the different T2s. Isambard Kingdom Brunel said:
15th May, 2008 at 09:11:42pm
On 15th May, 2008 Rob H said:
but there other differences between the different T2s. Bugger I'm turning into Donald Rumsfeld Isambard Kingdom Brunel said:
15th May, 2008 at 09:30:15pm
The comp housing on the Fester T2 it a bit different but that can be worked with. On 7th Nov, 2008 Nic said:
15th May, 2008 at 09:31:18pm
15th May, 2008 at 09:46:44pm
15th May, 2008 at 10:17:39pm
Yep ! Fiesta is 3 bolt iirc. |
15th May, 2008 at 10:34:18pm
Oooh, I'm wrong too then, I never noticed the 3 bolt flange. On 7th Nov, 2008 Nic said:
15th May, 2008 at 10:47:40pm
So are the conversion adaptors made to go from t3 to a specific t2? |
15th May, 2008 at 11:12:14pm
16th May, 2008 at 06:52:24pm
Cheers guys. |
