| Home > Help Needed / General Tech Chat > Lucas ignition amplifier module | |||||||
15th May, 2008 at 08:00:08pm
I have blown two of these in the last 100 miles and am now afraid to go out in case my last one gives up -it cost me £150 to be brought home last Tuesday at midnight.Any suggestions as to why this is happening, please ?.Also, is it easy to modify a points distributor to satisfy turbo requirements, as I have two of these. |
15th May, 2008 at 08:04:05pm
are these actually Lucas or intermotor.
15th May, 2008 at 08:04:51pm
Genuine Lucas and a proper "electronic" coil |
34 Posts Member #: 2156 Member wigan jnt 23 m6 |
15th May, 2008 at 08:22:28pm
bad earth?? that would cause a brakedown |
15th May, 2008 at 08:23:08pm
You also MUST use the heat conductive goop between the module and dizzy... On 17th Nov, 2014 Tom Fenton said:
15th May, 2008 at 09:25:33pm
On 15th May, 2008 tadge44 said:
Genuine Lucas and a proper "electronic" coil where are you getting them from, i thought they were NLA. carl |
15th May, 2008 at 10:05:08pm
Always used "the goop"Where are you suggesting a bad earth?.Secret supply - all ex AA van supplies since they went to Intermotor |
16th May, 2008 at 07:21:55am
i thoiught you have secret retailer somewhere,
16th May, 2008 at 08:36:25am
12H. Can you please amplify !! for me where you suspect the bad earth - I am getting to the point where I will revert to a points set-up, just so that I can get to an event next weekend 150 miles away. |
16th May, 2008 at 07:10:38pm
Edited by Bat on 16th May, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
17th May, 2008 at 11:11:23am
Thanks for that.Both checked and apparently OK(Starter spins pretty good too)Have gone back to points and on the advice of Aldon running max 26 degrees advance total.Will go back to electronic dizzy when I can spare the time and have the wife standing by with tow rope. |
17th May, 2008 at 11:49:07am
Your not feeding it with a ballasted supply are you?
19th May, 2008 at 06:24:32pm
No. Giving it the full 12 volts,same as the coil.Are these amplifiers polarity sensitive?.(Just in case I have been a complete prat and wired it in reverse, so to speak(There is a white wire and a black/white wire from the amplifier and I have wired it white to positive on the coil and black/white to the negative- negative earth system. |
19th May, 2008 at 06:35:09pm
Black/white to negative is correct.
20th May, 2008 at 09:01:53am
Good thinking !! I had thought the earth for the coil was via its wiring,or the distributor body.Thanks for that tip. |
