Home > Help Needed / General Tech Chat > MANIFOLD
PEP
Member #: 1145
North Wales
Awright people?? Just need to know the spec on these MIRAGE MANFOLDS. Does the inside of the manifold contain any deflector plates??? Also is there really any big difference btween that and a standard one??? Thanks for the advice!!
What do you mean, deflector plates? Like James Bond stuff?? I think you have to go for the deluxe version then!
Yes there is a big difference between these and the standard ones a few are:
-Stainless steel
-Possibility of no body cutting
PEP
Member #: 1145
North Wales
inside the standard manifold there internal plates(type of) that direct the gases downwards. If those mirage ones aint got that they must be shite.The gases would be fighting each other.!!
You've got a point, but many on this site have got good results with it. Anyway, the gases have only one way to go at last.
I agree that the two outer pipes pointing against each other are not optimum, but they atre good enough to give over 200hp.
in fact the 2nd fastest car on here runs one, (the fastest has a 16v head)
considering they are primaraly intended to prevent the need to cut the bulkhead they work well too.
PEP
Member #: 1145
North Wales
ill take it under advice but its like the principle of a straight through exhaust!!
the cast one does a good job! Ive had one priced at £200-based on a T3.
Yeah theyre wank, i dont know why anyone would use one
El Potter
Member #: 2169
Malta (Ex. Scotland)
Seriously Nic?
I though you were running a set.
And you can't argue with a 12 second quarter mile eh.
Warning:Stig in Training
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Least V, Least.
May as well not fit a turbo either. That weedy entry, and restrictive turbine wheel !!!!! Its bound to cause a massive restriction.
People have discussed design of the Mirage Manifolds for years, and their flow characteristics, however they produce the results.
Here's an old post on them:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10600
However if you want something that flows better and still fits without bulkhead mods how about one of these:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=213856
On 18th May, 2008 El Potter said:
Seriously Nic?
I am using them, i would use anything else myself
Im trying to resist the temptation for another set for something else at the moment
Least V, Least.
Yup, just saw it :)
mine seems to go ok on them...
