| Home > Technical Chat > Who can make me a custom plenum? | |||||||
![]() 143 Posts Member #: 1506 Advanced Member Cheshire |
20th May, 2008 at 12:17:42pm
Rather than an SU I use a Jenvey TB for a wet manifold setup. I need to get a plenum made up that will bolt to this, have a 25mm outlet for a dump valve and a 50mm pipe for inlet from an intercooler.
Edited by dn89mini on 20th May, 2008. Check out the (slow) progress at.......
20th May, 2008 at 06:17:50pm
contact Nic on this forum hes friend heywel will give you a price on this
20th May, 2008 at 06:39:39pm
20th May, 2008 at 06:48:22pm
Yeah Bat i though about that but the general thought seems to be you need a plenum, If I can get away without one that would be great, save me a ton of hassle too.
20th May, 2008 at 06:55:34pm
20th May, 2008 at 07:44:32pm
Hmmmmmm...
Edited by Rod S on 20th May, 2008. Schrödinger's cat - so which one am I ??? |
1391 Posts Member #: 1686 Post Whore Oxford |
29th May, 2008 at 02:07:07pm
indeed. ill be running on a setup smiler to yours. however with twin jenvey tb`s.
OMG Robert that's a big one |
520 Posts Member #: 2093 Post Whore Grenoble, France |
29th May, 2008 at 03:07:53pm
Before going MPi on my 1000 I had digital ignition (same ECU as the MPi) with a carb and stage1 Minispares intake (alu <something>torque).
std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
29th May, 2008 at 03:22:34pm
Just looked at the original pictures again...
Edited by Rod S on 29th May, 2008. Schrödinger's cat - so which one am I ??? |
29th May, 2008 at 04:42:21pm
On 29th May, 2008 retired said:
But I'm going for port injection, not throttle body, is that the subtle difference ??? Not really. As long as you stay with one throttle it's all the same. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
lol!
