Home > Help Needed / General Tech Chat > CAMBELT KIT
M111KYP
Member #: 1812
Live in birmingham and work sheffield
are cambelt kits worth fitting? is there any gain over the chain?
cheers
apart from slightley less noise ...no gains further
Gains IMO are 1, they dont stretch so time the cam in at what you require and you dont need to run 200 odd miles before the timing is correct. 2, they dont transmit crankshaft harmonics to the valve train.
But saying that Im taking my belt off and putting a chain back on simply cos its lighter.
Paul
Sir Yun
Member #: 1592
Smart Guy!
i had one cambelt die after 34km..thank you.
M111KYP
Member #: 1812
thats not good, think i might stick with a chain then
Sir Yun
Member #: 1592
Smart Guy!
the kit in itself is good but they should have used newer belt profiles as the ones used by MS use a rectangular profile (kinda old fashioned) and thus you can not just order a proper and stronger Gates/Pirelli item. minimania do a upgraded version btw.
My belt has been on for TEN years, soaked in oil at least twice, never let me down.
If you're running something like a 285 cam it wont stretch like a chain would.
What make was that, one of the cheap ones from Minispares?
Paul
Paul
what you need to do paul is make the big shitty heavy cam gear out of aluminium. [on the belt drive that is, ].
carl
pros and cons gents ......
with the above!..........??
Paul
Very true Carl, but Im fitting a chain with alloy centre cam sprocket from Swifty.
Paul
carl
hughesmarkie
Member #: 1197
Dublin Ireland
Im running one on my N/A clubby with VP8C cam and ive had no problems except oil leaks from the back plate!!!
I was tempted to run one on the turbo but I stuck with the chain... And I agree with Paul they dont seem to stretch like the chain.
I use a cambelt, as I could not find a chain long enough
I found a chain long enough but unfortantely it was for a chainsaw and thought it could be a bit dangerous! lol
you'd got through a lot of pulleys!
My 3.0 H6 Quad cam Subaru boxer engine has chain driven cams, these chains would be more than long enough I'd have thought?
And fingers. *laughing*
