| Home > Help Needed / General Tech Chat > Boost and cooling | |||||||
26th May, 2008 at 05:29:17pm
I,m the loony with the turbo A35 (ask your Dad)
26th May, 2008 at 05:39:11pm
24 deg total advance is best
26th May, 2008 at 09:14:55pm
27th May, 2008 at 08:12:59am
If the engine heats up quickly and get hot when in traffic then I would say that a bigger rad is needed. Fine if the fan is keeping it just cool enough, but wait for a hot day and you will be in trouble. The intercooler will do nothing for engine temps.
http://www.twin-turbo.co.uk
27th May, 2008 at 08:32:34am
And as for boost threshold problems, this is allrelated to your turbo specification and compression ratio.
520 Posts Member #: 2093 Post Whore Grenoble, France |
27th May, 2008 at 10:23:28am
Overheating in traffic means bad cooling or too much advance+lean low loads. This usually ends with autoignition, the engine keeps on running after the ignition is switched off.
std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
27th May, 2008 at 12:27:31pm
Many thanks for your contributions.Mapped ignition and a different turbo are not viable options for me, at the moment due to a lack of toy allowance.Will persevere with adjustments,particularly less advance and intercooler,together with more boost.Ran it up through the gears today at8lbs and it seems to survive OK.Definitely spools up quicker with less advance and a progressive throttle opening, rather than just flooring it. |
27th May, 2008 at 12:41:55pm
