Home > Help Needed / General Tech Chat > dump valve probs
stevenford_uk
Member #: 144
i have fitted a bailey piston dump valve to my mini, the problem is that it stays open for ages and does not shut till i am on full boost. so i cannot cruise properly.
i have taken the vacuum feed from the brake servo take off on the inlet manifold, on the little sticky up thing thats there as standard, i have noticed this is a one way valve into the inlet manifold, do i need to remove this and bypass it or just plum it into somewhere else?
can someone please help
thanks
b12
Member #: 247
Kent/Surrey Borders
hey mate . mine is in exactly the same place
that one way valve used to feed the breathers i think you will find !!
I just toke that off and drilled it out completely ; loadsa bits of white plastic fall out of it ; then it is no longer a one way valve !!!
I have had no problems with this ATALL ...
Good luck
steve
TurboLessTosser
stevenford_uk
Member #: 144
thankyou matey, thats what i thought of doing, but didn't wanna bodge anything, but i now may as well.
cheers dude
Or get a 5/8 unf bolt, drill it through then solder a piece of 1/4" OD tube into it *smiley*
Skinns46
Member #: 165
Cambridge
Because your taking from the brake servo and using a piston dump valve your getting to much fuel contamination which is not good for the seals and the piston sticks. Get a diaphragm type they don't suffer from fuel so much.
Roland
http://photobucket.com/albums/y139/Skinns46/
T3Tone
Member #: 252
Sunny suffolk
You can get special seals for them that dont swell with fuel contamination, someone did post the name of them a little while back but i cant remember who????
-MINI CLUBMAN 1380 TURBO-
T3Tone
Member #: 252
Sunny suffolk
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=1467
Viton *smiley*
