Home > Help Needed / General Tech Chat > Filler cap
Simon
Member #: 1865
Norwich, Norfolk
I have a fuel cell in the boot rather than the standard tank, i want to connect it with some samco or alike to the origional hole in the body, where can i find a filler attachment that will fit nicely on the body of the car to allow me to join it to the cell?
You could use a standard tank neck then connect it with a hose (use the proper petrol hose, silicon will dissolve)
Or a nice flush fit aero cap £££
Simon
Member #: 1865
Norwich, Norfolk
I thought about cutting the neck off the old tank, but im thinking it might move inside the hole of the body?
Sikaflex or something similar would glue it into the grommet, should be ok :)
http://www.merlinmotorsport.co.uk/FUEL-CAP..._149/index.html
my mate made a stainless widget that takes the std cap, but allows him to run a bit of tube to the tank so he can fill it up as per normal
If your interested i can see if he will make another for you in exchange for tokens??
Simon
Member #: 1865
Norwich, Norfolk
that would be great, photo too if poss?
