Home > Help Needed / General Tech Chat > Blocking anti run on valve? quick question
mayoturbo
Member #: 1395
chepstow
Do I block both pipes off or shall I connect them together so it just bypasses it?
Anything I have to do to the electrics or just unplugging it fine?
Both pipes? I though there was only one pipe and a meshed grill on the other end of the valve, or am I thinking of something else?
mayoturbo
Member #: 1395
chepstow
Just had a look the other pipe just leads down near to the gearbox and is open so blocking this would do nothing! should have looked before posting sorry.
Will block off the pipe coming from the carb
Ric
Member #: 36
Basingstoke
yeah, there's only one pipe. Don't get that confused with the balance pipe. I don't have the link to hand, but turbodave put together a really helpful thread on carb connections. Think it's in the FAQ or beginners tech section.
clubman91
Member #: 8923
North Wales
hi all i disconected this and blanked the pipe and the metro would not start so i put it back on and it ran am i doing somthing wronge or was it just a coincidence that this happend?
thanks
