Home > Wanted > T2, Plenum etc. turbo conversion: What have you got?
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Hello all, after runing into some trouble with a NA 1098 build I have decided to go with forced induction. With suitable superchargers being almost impossible to find over here I want to go down the T2 route.
Heres what I need:
Turbo HIF44 carb
Plenum
T2 turbo
Required turbo fittings (oil and water connections where necessary)
Actuator
Mirage manifold (although I accept I'll probably have to buy one new)
I'm sure I'm missing some stuff aswell
On 30th Apr, 2010 Rod S said:
Gary's description is best
GaryOS
Member #: 2810
Dublin, Ireland
http://cgi.ebay.co.uk/Garrett-Type-2-Turbo...0562407QQihZ013
Is this worth getting? I' still unsure as to wheater or not the T2 is too big. Bearing in mind that I want low boost (~7psi) as low down as possible, would I be better getting a GT15?
EDIT: I managed to get a carb and some other stuff off ebay. I now only need a turbo. Although I'll have to decide between T2 and GT15 first
Edited by GaryOS on 10th Jun, 2008.
Carl S
Member #: 1761
Stalker
You have PM :)
A GT15 could be just the thing *wink*
GaryOS
Member #: 2810
Dublin, Ireland
Thanks Gavin,
I'm starting to lean towards the GT15 alright. I'll start trying to find what cars they came from and get searching. I managed to get a turbo HIF44, plenum, pressure reg and pump on ebay today so just the turbo left to get
