| Home > Help Needed / General Tech Chat > Metro Radiator Setup? | |||||||
1050 Posts Member #: 764 Post Whore Staffordshire |
16th Jun, 2008 at 01:39:53pm
I'm in the process of getting my car ready for avon park. My rolling road session is booked for 26th of this month so time is limited. I'm converting to a front rad as my old side mount is knackered.
16th Jun, 2008 at 01:48:31pm
Im not using the metro rad (but similar), I used the hoses out of Rover 100, seemed to be all the bends I needed (along with the mini ones) and they were fook all to buy from the scrappy. 32mm is what I used.
Edited by matty on 16th Jun, 2008. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
16th Jun, 2008 at 03:28:12pm
dead easy to sort out ant, if you head over this way in the week we can go scrappy ratting and get some pipes.
16th Jun, 2008 at 03:41:15pm
Isn't the idea of that hose so you always have water circulating around cylinder 4 when the thermostat is closed though? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
16th Jun, 2008 at 06:01:12pm
yeah when the stat is closed it'll come up out of the heater take off and into the top hose, with the stat closed the only place it can go is into the rad.
17th Jun, 2008 at 10:53:38am
Hmm i have mine plumbed in the same way as marks i.e into the lower hose, use 32mm pipe everywhere and dont forget to drill the thermostat :) |
17th Jun, 2008 at 11:46:47am
ahh.. dont need to drill the stat, running a bypass hose :) |
17th Jun, 2008 at 06:44:50pm
im going to be using an MPI rad but not in the standard position, would it be ok using metal bends to connect up all the pipes and do you advise using 32mm pipes or are they to big? Drives
