| Home > Help Needed / General Tech Chat > Hazards | |||||||
18th Jun, 2008 at 07:15:46pm
Got a a strange problemo with my hazards at the mo.
18th Jun, 2008 at 07:20:41pm
check you've got the correct flasher unit - i think the indicator flasher can do this if fitted.
249 Posts Member #: 513 Senior Member Sheffield |
18th Jun, 2008 at 08:09:16pm
I had this problem the other week. Try taking the hazard switch apart and cleaning the contacts up. |
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
18th Jun, 2008 at 08:17:19pm
Probably nothing to do with anything, but could be useful to know with regards 'other' hazard problems - the in line fuse under the windscreen scuttle is also used by the interior light on some models' circuits.
Edited by Pottsy on 18th Jun, 2008. |
18th Jun, 2008 at 08:46:36pm
Thanks for the replies!
20th Jun, 2008 at 09:20:00pm
Just fitted a new hazard flasher unit.
20th Jun, 2008 at 09:42:44pm
yeah sounds like high resistance somewhere along the line to me. check the earth points first and then change a few bublbs over, easiest things to check i suppose, after that you will have to take someone else's advice because im to tired to think properly at the moment :) |
21st Jun, 2008 at 06:06:37pm
Ok been out looking at this hazard problem for a while now and still havn't cured it!
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
21st Jun, 2008 at 07:34:32pm
Mines doing exactly the same thing rich. With my problem though, right indicators arent working.
Back once again like a renegade master |
21st Jun, 2008 at 07:55:00pm
is it the correct flasher unit? do you have all the indicators you should have? ie have you taken out the indicators in the wings?
21st Jun, 2008 at 07:56:48pm
Did you take the switch apart? Sounds very much like the problem I was having, the contacts in mine were nicely corroded when I had a look. Run a bit of paper over the contacts and give it a squirt of contact cleaner.
21st Jun, 2008 at 08:23:50pm
On 21st Jun, 2008 Jordan said:
Mines doing exactly the same thing rich. With my problem though, right indicators arent working. I too have changed the flasher units. I think it maybe a faulty connection somewhere that has corroded or fell apart. I had this problem when first sorting the wiring after I bought the car. I seem to remember dodgey inline fuse holders and earths was what caused one side not to work!! On 21st Jun, 2008 mini_majic said:
is it the correct flasher unit? do you have all the indicators you should have? ie have you taken out the indicators in the wings? are the wires corroded as you said you had water in the flasher unit you might want to check the wires? apart from that i am not the best with these sorts of problems over t'internet because i dont have any experience of them unfortunately (or maybe fortunately?) James. I've got the side repeaters inside the car behind the glove box as i'm hoping to run without them, gonna wait till the MOT. But theyre all wired in and they all work fine when using the direction indicators! They all flash on the hazard aswell just at the wrong pace lol. Yeah i cut back the wires from the waterlogged flasher unit as they where indeed corroded but all properly crimped now! On 21st Jun, 2008 andygardner said:
Did you take the switch apart? Sounds very much like the problem I was having, the contacts in mine were nicely corroded when I had a look. Run a bit of paper over the contacts and give it a squirt of contact cleaner. Might also be worth looking at the main fuse box also, do the hazards run through there? I've tried a different switch but have the same problem! I cleaned up the prongs with some emery and sprayed contact cleaner over both plug and the back of the switch, again with no luck. But i didnt take the switch apart no that slipped my mind! Might be that both the switches I have tried are abit crusty inside I'll have a look at that!! The hazards dont seem to run through the main fusebox, each indicator and side repeaters do though and they work ok! Hmmm thanks alot for the replies guys! Gonna pop out and take apart the switch see whats what! |
21st Jun, 2008 at 09:53:17pm
Just cleaned up my hazard switch while the football's been on, it wasnt corroded at all inside and the other one was squeaky clean aswell.
21st Jun, 2008 at 10:05:45pm
I had this one on my indicator unit. However, it wouldnt work on the hazards Back once again like a renegade master |
21st Jun, 2008 at 10:23:37pm
21st Jun, 2008 at 10:36:23pm
Ahhh right, so ive got the wrong hazard flasher unit?
21st Jun, 2008 at 11:21:09pm
21st Jun, 2008 at 11:34:03pm
Hmm might do, i'll have a look in my box of bits tomorrow.
41 Posts Member #: 2397 Member Plymouth |
21st Jun, 2008 at 11:45:38pm
The coding noramlly relates to the wattage of the bulbs, your hazard flasher unit being 4 x 21W bulbs (Have you checked you have the correct wattage bulbs in the indicators?).
21st Jun, 2008 at 11:59:39pm
Ahh right again i'll check tomorrow cheers for the tip.
22nd Jun, 2008 at 12:22:37am
