| Home > Help Needed / General Tech Chat > Oz Pistons, quick Q | |||||||
487 Posts Member #: 1495 Senior Member |
22nd Jun, 2008 at 05:55:04pm
Im interested in buying these
22nd Jun, 2008 at 05:58:05pm
I have a set of these. They are a good NA piston.
Edited by Paul S on 22nd Jun, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Jun, 2008 at 06:01:37pm
are the 73 1330? |
22nd Jun, 2008 at 06:02:17pm
I hope they are OK, I order a set of there 998 pistons this morning for my clubby. Edited by Rob H on 22nd Jun, 2008. Isambard Kingdom Brunel said:
22nd Jun, 2008 at 06:10:02pm
On 22nd Jun, 2008 Rob H said:
I hope they are OK, I order a set of there 998 pistons this morning for my clubby. The flat topped 998 pistons will oil holes are great. The dished 998 pistons are standard type. I hope you ordered the right ones. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Jun, 2008 at 06:13:33pm
On 22nd Jun, 2008 mini_majic said:
are the 73 1330? good question is +94 1360? do you need to get the block offset bored like 1380? |
22nd Jun, 2008 at 06:14:26pm
These pistons were discussed here:
22nd Jun, 2008 at 06:16:32pm
are the 73 1330? 73mm is also +0.094" and gives 1360. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Jun, 2008 at 10:11:12pm
Are those Aussie ones imported 21253s or are they home made? Seems cheap though. On 13th Jul, 2012 Ben H said:
22nd Jun, 2008 at 10:17:13pm
One of mine was in a Right Way Industrial Co Ltd wrapper.
22nd Jun, 2008 at 10:30:24pm
I hope they are OK, I order a set of there 998 pistons this morning for my clubby. The flat topped 998 pistons will oil holes are great. The dished 998 pistons are standard type. I hope you ordered the right ones. Don't worry I did my home work and went for the the flat tops ones with the holes. Isambard Kingdom Brunel said:
