Home > Show Us Yours! > Quick Cam Sensor
This afternoon, I made a cam sensor.
Take an old 998 dizzy, strip and keep these bits:
Cut the casing down in the lathe. Make a top plate to carry the sensor and weld a bit of big end shell to the dizzy shaft:
Voila:
Edited by Paul S on 26th Jun, 2008.
Kean
Member #: 341
aka T2clubby
South Staffs
Excellent!
great!
although a tad more weld wouldnt go amiss on the big end shell,
And a big lump of weld opposite to balance it - but I'm a perfectionist....
The shell is welded at the outside, so should be OK.
I was thinking about putting a nut and bolt through the hole in the plate to balance it.
This is a quick fix for now. I'm thinking of either making it much shorter so that it does not get in the way of my planned intercooler. Alternatively putting the sensor on the front timing cover and a vane plate on the cam sprocket.
Yes, my planned design with the optical switch is also to be as shallow as possible - either for intercooler or front rad.
Unfortunately my chosen intercooler hasn't arrived yet (eBay win last Sunday) so I haven't done anything physical yet for the phase (cam) sensor but dizzy drive does seem the most logic if you can make it shallow enough.
Putting it on the timing cover on the end of the cam sprocket surely means running the hall switch in oil ???
bloody well done paul
Just the job! :)
Nice and simple :) me likey!
I know it is a temporary thing, but the balance of that will be a mile off and you might find it'll self destruct. Perhaps another piece of phase lump but twice as thick and half as tall will be a start?
Sir Yun
Member #: 1592
Smart Guy!
oh and something to get all the slop out of the jackshaft to minimize scatter (how accurate does a cam sensor need to be?)
I wouldn't have thought it needs to be extremely accurate, it's only to identify no1. I think the Rover ECU works on a 10 degree tolerance?
It only needs to sync the VR sensor to the engine cycle, so no real accuracy at all.
I will set it at TDC and see what happens.
