Home > Help Needed / General Tech Chat > solid engine mounts
sam_shelton
Member #: 251
Nottingham UK
I have just spent all day trying to fit my engine using minisport solid engine mounts and have concluded that they are not gonna fit without modification. Has anyone got any tips for fitting these? When bolted onto the engine they appear to be wider than standard mounts so I can get one side done but the other side won't drop down low enough to get a bold in.
Help please!
Sam
I has a similar problem.
I elongated the holes on the radiator bracket to effectively make the engine shorter.
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
had the same but just tapped the mount down with hammer and put somthing in the hole to locate it hope this helps
I had same probs with my dads S, i got 1 side in, then stood on the crank case and jumped up and down.
sam_shelton
Member #: 251
Nottingham UK
Thanks for the replies, so its not just me fitting them wrong. I have already tried jumping on the engine and it ain't moving. Why can't companies make things right? This is obviously a common problem. Looking at the quality of these mounts I am very tempeted to just fabricate my own mounts as I reckon I could do a far better job. One of the captive nuts has already come off and I have only put a bolt in it once!
Sounds a bit poo to me. Ive gone to Poly Flex ones after the experience with the S and they are much better, they still needed some shoe horning in but were fine.
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
Dont want to hjack this thread like a mother bitch but...
What is the best type of mount to go for in peoples opinion? And what are the differences as far as driving goes?
Ive just bought the standard rubber type. Ive got poly bushes on the subframe.
Ben.
Build Thread Click Here
genuine standard rubber on mine
alandavies215
Member #: 1844
I have solid mounts every were realy good but my fillings don't like them
to go with the coil overs my ribs take a bashing as well
i had those solid metal ones on my old 1380, i had to press the engine intot he subframe to get the bolts in
hated the vibrations aswell, giving poly ones a try this time
