Home > Help Needed / General Tech Chat > running alternator backwards?
Carl
Member #: 95
liverpool-on-sea
ive mounted my alternator on the outside of my engine on my starlet turbo conversion, ive seen this done a few times. but its stopped working after a short while.
can you run an alternator backwards? or do you have to do something else to it or is my alternator just knackered
thanks
carl
G13B
Member #: 1376
I do run mine backwards on the swift engine, no probs :cool:
//marcus
Check the brushes, they may be worn out or offset in which case they'll break off when ran backwards...
Carl
Member #: 95
liverpool-on-sea
sorted it was a wiring issue i.e i got 2 wires wrong way round. doh
Durrrrrrrrrr
Carl, is the alternator still running ok? I'm thinking ablout turning mine around to make more space up front.
PaulH
Member #: 2340
Dublin Ireland
Don't forget the fan guys, if the alt was ment to spin say for instance clockwise and you run it anty-clcokwise it will over heat. Unless you turn the fan trough 180 deg.
regards,
Paul.
On 17th Feb, 2009 Rob H said:
regards,
Paul.
Or if you turn the fan round will the blades be angled in exactly the same direction.....?
PaulH
Member #: 2340
Dublin Ireland
sore matt you totly right I ment to say you will need to get a clock or anty-clock fan No idea why I wrote that probly a senior moment :(
Carl
Member #: 95
liverpool-on-sea
yep seems fine mate. ive done a few miles in it now (touch wood)
