| Home > Help Needed / General Tech Chat > Hazzards working indicators not | |||||||
1st Jul, 2008 at 11:03:06am
Any thoughts, My hazzards are working fine but my indicators are not, i have put a new switch on still not working. Fuse is ok, connections seem fine and clean. MOT is on Saturday morning |
1st Jul, 2008 at 11:06:07am
By new switch do you mean flasher unit? |
1st Jul, 2008 at 11:13:08am
go for the flasher unit
1st Jul, 2008 at 11:21:45am
you can try joining the wires on the flasher unit to see if that is the problem or not. On 15th May, 2009 TurboDave said:
1st Jul, 2008 at 12:00:35pm
have bought a new flasher unit still not working |
1st Jul, 2008 at 12:12:00pm
When I had this problem, I cured it by replacing the fuse box.
1st Jul, 2008 at 12:54:11pm
tis a new fuse box already. Someone has suggested the hazard switch might be knackered causing the probelm. |
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
1st Jul, 2008 at 01:27:24pm
there are two flasher units dont forget. |
1st Jul, 2008 at 01:34:01pm
have not forgot that.
1st Jul, 2008 at 01:42:20pm
my guess would be hazzard switch On 15th May, 2009 TurboDave said:
1st Jul, 2008 at 01:48:10pm
Replace various components with wire one by one until the lights come on.
1st Jul, 2008 at 02:34:22pm
On 1st Jul, 2008 matty said:
Replace various components with wire one by one until the lights come on. If you bridge the relay out the lights should stay on. Are you getting 12V at the relay for the indicators? Check the connections at the stalk connection also (Power supply to stalk switch and continuity accross switch). relay? wasn't sure that there was one, i thought it was just fused. if there was one and it was not working then surely the hazards would not work |
1st Jul, 2008 at 04:07:57pm
I mean flasher relay/unit https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
271 Posts Member #: 1844 Senior Member BURNTWOOD, staffordshire |
1st Jul, 2008 at 06:46:52pm
hello
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
1st Jul, 2008 at 11:34:24pm
this may sound really stupid, but have you tried putting an indicator on whilst the hazard switch is on. my mates estate will only work like this and i cant figure out why lol On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
2nd Jul, 2008 at 08:26:06am
all fuses have been checked, have checked hazard switch by bridging the top two connectors, the indicators work, so i can only asume the switch is ok.
2nd Jul, 2008 at 07:08:22pm
2nd Jul, 2008 at 07:57:34pm
Have you checked the in-fuses on the bulkhead in the engine bay?
2nd Jul, 2008 at 10:10:03pm
i have checked the wiring and fuses but can't find anything wrong, so have put a live onto the flasher unit to get through the mot. all working fine at the moment |
. If your bridge it with wire across the 2 wires the indicators should stay on.
