| Home > Help Needed / General Tech Chat > fuel gauge | |||||||
271 Posts Member #: 1844 Senior Member BURNTWOOD, staffordshire |
1st Jul, 2008 at 09:21:47pm
hello all
1st Jul, 2008 at 09:28:30pm
1st Jul, 2008 at 09:37:00pm
hi
1st Jul, 2008 at 11:06:30pm
2nd Jul, 2008 at 06:19:49am
thanks bar will try that first |
2nd Jul, 2008 at 07:36:07pm
have you put new clocks in? my mini's fuel gauge goes past full and past empty before it runs out! with my old guages it was fine Drives
2nd Jul, 2008 at 07:48:58pm
no they are the original gauges carnt understand it working then just stop |
5th Jul, 2008 at 08:08:55pm
I'm having a problem with mine too. Just got the car on the road and the petrol gauge doesn't work.
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
6th Jul, 2008 at 01:53:03pm
Rich do u have the 3 clock dash ? As mine did this a while ago and it was the plug at the back where it went in to the PCB it move some of the PCB pick ups and all hell broke loose. Just make sure its plugged in correctly and no sitting skew or somethin
6th Jul, 2008 at 01:56:59pm
Do the later 3 clock dashes have voltage regulators? Isambard Kingdom Brunel said:
6th Jul, 2008 at 03:47:29pm
hello
6th Jul, 2008 at 04:08:14pm
On 6th Jul, 2008 pinkyandnobrain said:
Rich do u have the 3 clock dash ? As mine did this a while ago and it was the plug at the back where it went in to the PCB it move some of the PCB pick ups and all hell broke loose. Just make sure its plugged in correctly and no sitting skew or somethin Cheers Dan Yeah i've got a 3 clock pod, checked the connections on that crappy pcb sheet where the plug connects and it all seems to be ok! On 6th Jul, 2008 Rob H said:
Do the later 3 clock dashes have voltage regulators? Yeah I did some reading and from what i can tell the older ones, made by Smiths have the voltage stabilisers on the back of the pod. The newer ones made by a jap company have the voltage stabiliser hidden away inside the pod itself! My mate's got a spare 3 clock pod, the older type which im gonna try. Will help me to determine if its the stabiliser or the sender/associated connections!! Not sure why the two backlights arent working and the temp gauge goes skitz every now and then but I hope trying the new one will show me where the problemo is! |
6th Jul, 2008 at 04:23:49pm
6th Jul, 2008 at 04:28:27pm
On 6th Jul, 2008 Bat said:
Hi, Rich, that'll be a bad earth in the boot
Cheers, Gavin :) The earth on the tank? Haynes said its earthed through the numberplate lights and the main earth harness in the boot is a strong one!! Mind you i did see a spare earth wire floating around with a spade connector on the back not connected to anything, forgot about that i'll go check... Edited by richminiturbo. on 6th Jul, 2008. |
6th Jul, 2008 at 06:41:19pm
