Home > Help Needed / General Tech Chat > Proximity of the slave to turbo...
Mikes1098
Member #: 2190
South Carolina, USA
I am planning on mounting my turbo over the flywheel housing on a 1098. I noticed that this will put the slave in close proximity to the exhaust side of the turbo… Has anyone had heat problems? What are some possible solutions? Or will it be ok? Do they sell a small hydraulic throw out bearing conversion? Pictures of your solutions are always welcome…
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
If you completely clean out your old slave, master and clutch line (or replace them) then couldn't you use dot 5 brake fluid? It has a boiling point of something like 500degrees F
On 30th Apr, 2010 Rod S said:
Gary's description is best
There is always this if you are woried
http://www.shengineering.co.uk/pcmclutchkit.aspx
SumpNut
Member #: 28
on the janspeed ones didnt tthey relocate the slave behind the engine and use a long push rod to actuate the clutch?
Mikes1098
Member #: 2190
South Carolina, USA
How does that work....does it use a cable?
Does anyone have pictures a a Janspeed setup...it seems to similar to what I was going to try and do.
There used to be some pictures on here somewhere. You could also try exhaust wrap to keep the heat down.
