| Home > General Chat > connecting MJ V4 to pc | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
4th Jul, 2008 at 06:28:24pm
My mega jolt won't connect to the pc, got the com port right, can't get the firmwere software to run. so its all abt foobar. Help me computer type people!
Edited by Alex1340 on 6th Jul, 2008. |
6th Jul, 2008 at 12:29:08pm
o dear |
41 Posts Member #: 2397 Member Plymouth |
6th Jul, 2008 at 12:32:52pm
Check all the components and connections around the Max232 IC, this controls the serial interface. |
6th Jul, 2008 at 12:39:14pm
Some people have problems using some usb-serial converter leads if thats what your using. If you have not already done so i would bung a post on the megajolt site or do a search on there as most problems have been covered on there before.
-MINI CLUBMAN 1380 TURBO- |
6th Jul, 2008 at 12:52:50pm
Mine wouldnt work with the usb to com port lead, Have you tried it with a computer with a serials port?
6th Jul, 2008 at 03:54:19pm
To help narrow down the problem, does your PC (laptop?) have a genuine serial port or are you using a USB/serial convertor (as suggested above) ??? Schrödinger's cat - so which one am I ??? |
6th Jul, 2008 at 07:50:06pm
hi guys, right point im at. I have tried it on my laptop with a usb to serial and on a laptop with a serial port running XP. Both give me the same results, timeout error. its the new V4 unit so i made my own cable but i have checked that over with the multi meter and i have also re-check and checked again the voltages across the unit and it all seem right. so im well stuck. |
6th Jul, 2008 at 07:53:30pm
6th Jul, 2008 at 08:08:32pm
baud rate?? Where do i do that?
6th Jul, 2008 at 08:49:57pm
Edited by Bat on 6th Jul, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
7th Jul, 2008 at 01:15:59pm
If you made your own cable did you wire it pin to pin (identical numbers) or Rx to Tx and Tx to Rx etc. Schrödinger's cat - so which one am I ??? |
7th Jul, 2008 at 09:06:25pm
i wireid the cable as per the pic on there web site. using the serial pin numbers. Im not really up on RX TX stuff? do i need to have a cross over or somthing?
7th Jul, 2008 at 11:08:26pm
Sorry, I hadn't realised they were using an RJ11 connector instead of a DB9.
8th Jul, 2008 at 07:45:04am
i bought a phone cable with the RJ11 already on then cut the other end and wiried a DB9 plug on to it. the db9 is numberd on the front side so i went by the number on that to the pic on the MJ website. Also checked there photo of there wired up db9 and it looks the same. |
8th Jul, 2008 at 08:17:40am
Sounds like the cable should be OK then, although might be worth just checking you've got what you think you have got by doing a continuity check with a DVM/multimeter between the relevant pin numbers.
8th Jul, 2008 at 09:18:51am
8th Jul, 2008 at 09:58:50am
On 8th Jul, 2008 Bat said:
You have have to reboot before it will see the serial mouse. Yes, sorry, it's so long since I've used a real serial connector, I'd forgotten that !!! On 8th Jul, 2008 Bat said:
I can access my ECU with the terminal program to test coms, can this be done with MJ? Alex, why don't you ask that specific question on the Megajolt (AutosportLabs) forum ? I know you can with Megasquirt (its part of the build process to check the serial coms) but isn't obviously so with MJ. Edited by Rod S on 8th Jul, 2008. Schrödinger's cat - so which one am I ??? |
8th Jul, 2008 at 08:36:35pm
i've posted the same question and we have been gong though fault finding but still having same problem checked all the pins and that lot. still nothing. getting fed up now. Any one want to swap a V4 for a V3? lol |
8th Jul, 2008 at 09:15:04pm
8th Jul, 2008 at 09:55:01pm
aparently its possible to use a hyperterminal program that came with some v of windows but not vista, i've downloaded on buti don't understand how to work it. Found a guy who builds these units who says he will take a look at it if i can post it to him. |
8th Jul, 2008 at 10:40:54pm
11th Jul, 2008 at 06:17:36pm
fixed it, im using my old laptop to program the unit. just got to create my map |
11th Jul, 2008 at 07:22:21pm
What was the problem then ??? (might help someone else in the future to know...) Schrödinger's cat - so which one am I ??? |
27th Sep, 2008 at 05:30:56pm
Hi, rather than start a new thread, thought id use a new one.
27th Sep, 2008 at 05:53:58pm
Never mind.
