Home > 998cc > 998 t2 which gearbox
blister
Member #: 2590
Croydon
would it be beneficial to put a 1275 gearbox or a 850 gear box on my
mini ? will also be running nos so do i have to lower the compression ratio any more then what i would?
Yes it will be beneficial to put a 1275 gearbox or 850 gearbox on your car, otherwise, the engine will fall on the floor and you won't have any drive.
IMO, the best boxs are A+ 998s.
blister
Member #: 2590
Croydon
i got a full 998 engine would it be an ok gear box on that or would i get better torque from a 850 or 1275?
youl find the 850 box will produce alot of torque..
blister
Member #: 2590
Croydon
with nos and a turbo will it not be a bad idea
What matters for "torque" isn't so much where the box came from, but what gear ratios it has inside, and especially, what the Final Drive ratio is.
If none of these have been changed since the gearbox left the factory, as a general rule, the smaller the engine, the higher the number of the FD ratio which actually means more "torque" at the driveshafts (so better accelleration) but a lower top speed.
You need to know what the internal ratios (1,2,3) are and what the FD ratio is before deciding.
are you really gonna run a box over 20 years old with MOS and a turbo and expect it to last?
x-pin diff minimum,
if not a s/c gearset,
what power are you aiming for?
80bhp?
Hmmm.
Missed the post immediately above mine (was too slow typing).
New answer... how many bits do want to come out of it after the loud bang ???
The ratios won't really be important unless you want to know how many teeth should be broken.
Sam
Member #: 1686
Oxford
he said on tmf 180bananas. *hehe!*.
OMG Robert that's a big one
def the 850 box then
may i also ask to see the montego head fitted?
cheers
joe
WTF, is this Minifinity??
Vegard it's like this place but most of the bulbs are out! *tongue*
evolotion
Member #: 83
Glasgow, Scotland
x2 .. never heard of it.
Denis O'Brien.
Sam
Member #: 1686
Oxford
hes gunna build it up go out with it for the first time.
2nd gear kane it and stack it into a bush or break the gearbox.
my bet is both.
