Home > Help Needed / General Tech Chat > megajolts to controll rad fan
Alex1340
Member #: 111
Loughborough
Has any one tried using one of the user outputs on a mega jolts to switch a relay for a elec rad fan? I've got the new v4 which can take a feed from a temp sensor, i'm not sure the software can switch output on once it get to a certian temp but i do know it can be done from the rpm read out. so i could have the fan running between say 500rpm and 3500rpm, rough geuss in any gear 3500rpm will be above 30MPH at which point i think (correct me if i am wrong) the elec rad fans stop helping the cooler and its all done with airflow.
any one tried it?
You really need it switched on temperature because if you're running around town it'll never warm-up.
Ben H
Member #: 184
Melton Mowbray, Pie Country
To me it sound like a reasonable solution without a temp sensor. Best thiing to do is try it and then tune it. I would advise putting in a switch on the dashboard too though so you can switch it off on cold days.
Can I just say though that this is why I use megasquirt not mega jolt. All of the little thing like this that you think of can be be done with megasquirt and for hardly any more initial outlay.
http://www.twin-turbo.co.uk
Alex1340
Member #: 111
Loughborough
worked it out, you can trigger a user output from the temp configed input. nice and easy. just got the calibrate it right.
just_jack
Member #: 2928
peterborough
Bringing out a old post,
How was it you did this Alex? If you can remember
Or if anybody else knows
Regards
Jack
Jack Jones
Alex1340
Member #: 111
Loughborough
Wow really digging up an old post. In the end I just got a temp switch and a relay. Seemed cheaper and easier.
just_jack
Member #: 2928
peterborough
thats the way i was going to do it, but i thought i would try and make the most of the megajolt,
thanks though alex, i appreciate the reply
kind regards
jack
Jack Jones
