| Home > Help Needed / General Tech Chat > Boost pressure drop | |||||||
2nd Aug, 2008 at 06:33:35pm
I cant figure out why, when I rev to about 4500/5000 rpm the boost starts to drop.It rises steadily(rapidly) to the setting I am using(about 9/10 psi) and then drops away to 5 or less as the revs rise.
2nd Aug, 2008 at 06:51:59pm
3rd Aug, 2008 at 03:10:02pm
Is there any way to change the spring in the standard actuator ?.If it is weak Im told there is very little point in trying to pre load it -Im still budgeting for a decent actuator. |
3rd Aug, 2008 at 04:00:06pm
3rd Aug, 2008 at 06:48:45pm
Thank you -will try it when I have finished the body repairs. |
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
4th Aug, 2008 at 01:57:07pm
mine did that when i had a crap actuator and bleed valve. Replaced it one and uprated one with a fair bit of preload and its fine now. |
