Home > Help Needed / General Tech Chat > air filter position
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
hello all
I have my air filter positioned in the inner wing right up by the scuttle pannel (got no inner wings by the way) but the pipe doubles back on it's self, this morning I was thinking of moving the pipe so it is positioned under the front valence, the air filter won't fit so was going to take it off and put a couple of pairs of tights over the end to stop the shit, the question is is this good enough as I think it will give more air flow
Thanks
No way! No tights unless you've torn them off with your teeth!
Proper air filter or nothing, tights don't filter and restrict air flow!
alandavies215
Member #: 1844
hello
Ok batt noted
Were can a buy a filter sock to fit over 50mm pipe Deamon Tweeks site is down as I said don't have room to fit a proper filter
Thanks
If your motor is turbo'd, I think so, I don't think a fliter sock will be upto the job.
Have a search round on this site see what pics you can find of how others have done it.
A proper filter in the wrong place will protect the engine, a poor filter in the right place doesn't :(
Pipercross make a small one.
alandavies215
Member #: 1844
hello
Sorry to bother u people again has any one got a link I can go to as I'm only guessing on what two buy all I want is some thing that will go on a 50mm pipe but not to big as ive not got a lot of room
Thanks in advance
if you dont have alot of room and no inner wings cant you do somthing down by an indicator or somthing? you should get a reasonable amount of ait there with a little scoop or somthing and it doesnt get in the way of the engine bay :)
alandavies215
Member #: 1844
hi
I thought if I put the pipe just under the front valence ( not in the engine bay ) it would act like ram air forcing the air up the pipe as in direct line with the air and not just sucking it in
What do u think
if you make your self a little box to enclose the air filter and put it in a position to get a nice feed of air anywhere where you have free space should work a treat, like you said i could (not sure if it would with the amount a turbo suck in) be like a "ram air" air intake
