Home > Help Needed / General Tech Chat > Disc confusion
El Potter
Member #: 2169
Malta (Ex. Scotland)
Hi lads.
Need some help.
Was looking through the million and one articles about putting metty discs on a Mini.And been getting very confused cos I don't know what a flange is or which bit the hub is!
Anyone care to point out all the different parts?Or maybe a link to some drawings or something?
Thanks a lot
Tom
Warning:Stig in Training
Carl
Member #: 95
liverpool-on-sea
the flange is the round bit with the 4 wheel studs on, the first bit you see when you remove the wheel. this is bolted to the disc with 4 bolts.
the hub is the big bit behind the disc which houses the bearing and the balljoints.
you could do with a haynes manual mate.
El Potter
Member #: 2169
Thanks Carl.
Where is it in the Haynes?Couldn't find it in mine.
Or is it in the Metro one?
A quick google search should point you in the right direction. :)
El Potter
Member #: 2169
I knew this would happen*happy*
Doesn't take long to hit the gutter with you guys does it!!
Seriously though,I need to figure all this shit out so I can start this goddamn van someday.
I can't help, I took the frowned on approach and bolted the whole metty assy to my Mini. I've not touched ball joints in 10 years *happy*
El Potter
Member #: 2169
But doesn't that fuck up your handling Gav?Cos of track width and kingpin alignment or something.
I've heard all the stories about this, but I don't slow down for corners, usually accelerate and can't fault the handling.
I'm more than happy I don't have to reshim ball joints for every MOT *happy*
El Potter
Member #: 2169
Right.But you've got 13 inch wheels right Gav?
Maybe that makes a difference? Cos I'm going with 10s.
