Home > Help Needed / General Tech Chat > Push Rod Sleeve? Where or anyone make one?
JordieNE
Member #: 1591
Prudhoe, Newcastle
Hello all.
Im after somewhere that sells or can make me a push rod sleeve. i have a 1275cc unleaded head in the garage, but it seems that someone as attempted abit of home porting on it and gone too far. Its got a tiny nick in the wall but oil passes through it when i checked it. I am wondering if i can just sleeve the push rod hole and use the head as i need a head for the 1275cc engine im building at the moment.
Thanks all
Jordie
use a valve guide, and then open it up to the size you need.
I'd use steel, not iron. The valve guide will become so thin that there's a possibility of collapsing. They're real brittle.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=132698
i ended up using some thinwall alloy tube on ebay iirc
