| Home > Help Needed / General Tech Chat > MPI Overheating | |||||||
![]() 59 Posts Member #: 2176 Advanced Member |
9th Aug, 2008 at 11:29:31am
Hi guys
9th Aug, 2008 at 01:09:50pm
where does the temperature gauge needle sit when driving, and then where does the needle sit when the engine is starting to overheat? Above below or bang on the white line?
Edited by Sprocket on 9th Aug, 2008. On 26th Oct, 2004 TurboDave16v said:
9th Aug, 2008 at 01:14:10pm
when it is running down the road and the motorway and stuff it sits just normal but and soon as it is standing for more than 5 mins it heats up and then i always shut it off before it hits the red mark on the gauge the fans are not kicking in, should the car need them when it is sitting there or is there a bigger problem?
![]() 338 Posts Member #: 1911 Senior Member Swindon |
9th Aug, 2008 at 01:21:35pm
Could be the senor on the thermostat housing thats gone. |
9th Aug, 2008 at 02:54:52pm
Not if the gauge is responding.
9th Aug, 2008 at 02:59:19pm
is that located in the main fuse box or is it in another location? |
9th Aug, 2008 at 07:21:05pm
9th Aug, 2008 at 07:33:40pm
Here is the Rover Workshop manual wiring diagram On 26th Oct, 2004 TurboDave16v said:
10th Aug, 2008 at 11:20:36am
fan switch ?
10th Aug, 2008 at 11:35:20am
10th Aug, 2008 at 11:53:39am
10th Aug, 2008 at 07:14:24pm
when i moved my wiring loom i put the fuse box up in the dash so i no longer have the cover which has the diagram on the inside with which fuse go's where, can any one take a picture of this for me, i would normaly use the haynes manual but i have no idea where it has gone in the move |
10th Aug, 2008 at 09:16:36pm
18th Aug, 2009 at 01:26:05pm
Hi guys its back mpi still overheating, i got a few good months and now it has returned, this time with immense pressure in the system.
