| Home > Help Needed / General Tech Chat > Plugs flooding! | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
9th Aug, 2008 at 03:29:40pm
Hi all
Shit Happen's |
9th Aug, 2008 at 03:34:58pm
over fueling big style by the sounds of it or your not getting a proper spark? have you done anything to it recently? Drives
9th Aug, 2008 at 03:37:37pm
about 400 miles ago yeah lol
Shit Happen's |
9th Aug, 2008 at 03:58:43pm
Spark dont seem to bad ?
Shit Happen's |
9th Aug, 2008 at 05:14:09pm
like paul says spark
9th Aug, 2008 at 07:23:42pm
![]() 199 Posts Member #: 1277 Advanced Member Portsmouth |
9th Aug, 2008 at 09:12:17pm
I had a flooding problem with my carb this weekend, it was the float valve sticking like Steve said. Took the carb off, flipped it upside down, blew threw the fuel inlet and the valve was still open. So took the float and valve out and just cleaned it all up. Then refitted it and when i blew threw the fuel inlet after that it seemed to be fine. |
9th Aug, 2008 at 10:32:45pm
I got it started again, but had to keep the reves up. did that for 5 minutes, then took my foot off the pedal, and it just cut out again. so trying to get the carb out now. shaun, did you take the carb off with the inlet manifold and
Shit Happen's |
10th Aug, 2008 at 08:11:05am
take the dashpot off the carb while its all still connected, then switch on the ignition so the fuel pump kicks in, look down the carb and see if fuel is coming up out of the jet. if it is then the needle valve is either blocked or knackered.
11th Aug, 2008 at 04:10:13pm
On 9th Aug, 2008 Shaun87 said:
I had a flooding problem with my carb this weekend, it was the float valve sticking like Steve said. Took the carb off, flipped it upside down, blew threw the fuel inlet and the valve was still open. So took the float and valve out and just cleaned it all up. Then refitted it and when i blew threw the fuel inlet after that it seemed to be fine. I did what you said there. and fuel started coming out. So try it again, and can't blow thou it now.. that mean the valve was stuck open then ? Cheers Shit Happen's |
11th Aug, 2008 at 04:25:00pm
An easy trick to try, without removing the carb is to disconnect the power to the fuel pump & run the car until it empties the float bowl & the engine dies. Now reconnect the power to the pump & allow it to fill the float bowl. The fresh wash of fuel usually removes any debris from the valve/seat and allows it to seat properly. Now try restarting.
11th Aug, 2008 at 05:06:56pm
Yer sounds like your valve was stuck open like mine. If you cant blow through the inlet now whilst the carb is held upside down, the valve should be seated correctly.
I had a flooding problem with my carb this weekend, it was the float valve sticking like Steve said. Took the carb off, flipped it upside down, blew threw the fuel inlet and the valve was still open. So took the float and valve out and just cleaned it all up. Then refitted it and when i blew threw the fuel inlet after that it seemed to be fine. I did what you said there. and fuel started coming out. So try it again, and can't blow thou it now.. that mean the valve was stuck open then ? Cheers |
11th Aug, 2008 at 05:43:22pm
On 11th Aug, 2008 Shaun87 said:
Yer sounds like your valve was stuck open like mine. If you cant blow through the inlet now whilst the carb is held upside down, the valve should be seated correctly. By the way, just saw your other post. Fuel had flooded into my Plenum as well when i was having this problem. On 11th Aug, 2008 Mini_Uk said: On 9th Aug, 2008 Shaun87 said:
I had a flooding problem with my carb this weekend, it was the float valve sticking like Steve said. Took the carb off, flipped it upside down, blew threw the fuel inlet and the valve was still open. So took the float and valve out and just cleaned it all up. Then refitted it and when i blew threw the fuel inlet after that it seemed to be fine. I did what you said there. and fuel started coming out. So try it again, and can't blow thou it now.. that mean the valve was stuck open then ? Cheers Thank god for that :) lol nice one.. allsorted I's it very common for the valve to get stuck open then. Is there anyway to stop it from happening again. or is it just one of those things ? Cheers :) Shit Happen's |
