Home > Technical Chat > NO body mods turbo
CraigyBoy
Member #: 3379
Staffordshire
I've seen a few turbo a-series engines in minis with no body mods.
What turbo do they use and how available are the parts?
Sensible question (sorry)- What Mpg can be achieved with this setup in a mildly tuned 1275?
Thanks
D.I.L.L.I.G.A.F
You'll be talking about the Mirage Motorsport kit. These manifolds are for fitting a T2/25 Turbo and require no bulkhead mods.
Stainless three piece kit, costs £350 iirc
The fastest 5port Turbo Mini in the country uses these, as do plenty of others.
Si P
Member #: 912
North Yorkshire
* Search * Button top right-----> *wink*
Mirage...?
Si
You can get 40 MPG apparenlty on a fairly standard 1275 turbo.
http://www.miragemotorsport.com/
http://www.flickr.com/photos/dazecoop/1259577192/sizes/o/
as you can see , no body mods whatsoever,lol
PMFSL!!
turbominij
Member #: 2104
Essex - UK
i run a no body mod t2 turbo on mirage manifold.
thing you need to realise first:
1. is that you need to mod the turbo to make the actuator sit on the other side which means making a bracket to hold it.
2. that you need to sort out a oil drain from the turbo (can be a pain but is possible)
all of which you will find information on here about :)
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
il dig out some pics of my bracket and oil feed...
