| Home > Help Needed / General Tech Chat > Inlet......... | |||||||
39 Posts Member #: 2402 Member |
17th Aug, 2008 at 02:09:26pm
Hi guys, I'm putting a blow superchager setup with eaton m45, and I don't know if is better to use the metro turbo inle or the mg N/A inlet.....
Edited by Giancooper on 17th Aug, 2008. |
17th Aug, 2008 at 10:47:22pm
Someone can help me? |
17th Aug, 2008 at 10:52:21pm
17th Aug, 2008 at 11:37:20pm
The Turbo manifold flows nearly as well as the NA MG one, only very slightly less. Fastcarl flowbench tested both i believe. |
18th Aug, 2008 at 08:03:23am
Just put the one on that fits best for your application. Both are commonly used on turbo motors and there would not appear to be anything in it. http://www.twin-turbo.co.uk
444 Posts Member #: 2885 Senior Member |
21st Aug, 2008 at 10:52:25pm
Turbo design manifolds use the Log-type of construction to to keep the mixture turbulent by literally making it bash into the sides of it due to the accute angles used. No? |
976 Posts Member #: 3228 Post Whore North of the Netherlands |
22nd Aug, 2008 at 05:08:29pm
Is the charge starvation in a turbo totally different from a NA engine; because in NA engines have the outer two cylinders go lean..?
Dazed and Confused.... |
26th Aug, 2008 at 06:31:28pm
Hmm, found out that my theory is indeed stupid...
