| Home > Beginners Tech > Malpassi fuel pressure regulator question | |||||||
![]() 70 Posts Member #: 854 Advanced Member Fareham, Hampshire |
19th Aug, 2008 at 10:58:11pm
Hi all, I had a quick look through the search function but couldn't find a definitive answer for this.
19th Aug, 2008 at 11:07:27pm
19th Aug, 2008 at 11:08:32pm
Yes, that's exactly what such a FPR is for !!!!
20th Aug, 2008 at 08:01:35am
When you say it is putting too much pressure through what are the symptons. You should not need a regulator with the fuel pump you are using.
http://www.twin-turbo.co.uk
20th Aug, 2008 at 08:02:19pm
Yes it is an SU carb, an HS4.
20th Aug, 2008 at 10:10:08pm
would i be right in saying that at idle the Pressure will be 3.5psi but the FLOW will be low as it is not being used. but then at full chat you would still have 3.5psi pressure but a HIGH FLOW to cope with the needs? |
20th Aug, 2008 at 10:11:36pm
I and many other people have run this setup with no problem. The pump is quite happy pumping against the float bowl valve. Do you think that a mechanical pump on the cam stops when the float bowl is full?
21st Aug, 2008 at 08:07:33am
Someone is getting confused messages I think.
21st Aug, 2008 at 10:14:18am
we use the red top pumps on the miglia's they do stop ticking when the fuel pressure is high enough On 15th May, 2009 TurboDave said:
28th Aug, 2008 at 10:38:57pm
So would that suggest my fuel pressure is not high enough then, it drives very well (as far as I am aware).
28th Aug, 2008 at 10:51:08pm
get a Feul pressure Gauge mate. The only way to do it properly. |
