Home > General Chat > Piper 285/2 Q (N/A! not turbo)
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
I have access to a Billet Piper 285/2 camshaft, the only thing with it is the guy whos got it has had it modified by piper to reduce the over lap by 10degrees, how will this affect the performance of the camshaft??? Does it effectively make it a 275???
Ben H
Member #: 184
Melton Mowbray, Pie Country
why not ask the guy who had it done? He surely knows how it will affect the performance.
http://www.twin-turbo.co.uk
Sam
Member #: 1686
Oxford
i may be shooting at fish here and off entirely. but its 8 in thr morning and im gunna give some advice that might turn into a finity...
i presume this alters the lobe seperation angle lowering it meaning the cam is more suited to a head with smaller valves.
or to a engine with a slightly smaller displacement.
eg smaller cc to head valve area ratio
Edited by Sam on 22nd Aug, 2008.
OMG Robert that's a big one
If the overlap has been altered to be 10 degrees less, then assuming the duration hasn't changed, the LCA will actually be wider.
I know this won't help you much, but in my old 1380 i had a cam shaft that was based on a 285 piper, but they made it less lumpy and a bit smoother to drive but regrinding it, it still had massive life but less duration, the result was a more driveable car with 115 bhp at Fly, so still not to bad power. It sounds like your cam might be the same sort of thing.
eaton_mini
Member #: 1649
Well the guy had it modified so he could use it with his supercharger setup to reduce the valve overlap and obviously emissions.
Im not going forced induction, but Ill be using a 7port with 38 and 31mm valves fitted................oh and 1380.
Well it'll still be 285 in duration, the lower overlap period will make it run smoother at the bottom end and improve economy a little(?) but may reduce top end HP...
Sam
Member #: 1686
Oxford
why bother, its not that lumpy really.
with a kent 296. took it out and its stamped into the end i thought it was a 276 then a 286.
mine is still running on a dizzy. admitadly i cant go above 2nd gear in town without feeling the lumpy gudder.
sams got the right idea^^
Sam
Member #: 1686
Oxford
watch as the flames comes in.
a 296 just isent enough.
so im ordering a bp320 come pay day and putting a weber on it.
Edited by Sam on 26th Aug, 2008.
i concur, a 296 isnt that mental
eaton_mini
Member #: 1649
but it would be nice if it didnt have to idle at 1500rpm!!
1380 with a 7port head, shouldnt need to go mad with the cam to make nice power......................hopefully. I know its a different kettle of fish to the 5 port as to how it reacts to a cam, read somewhere about cams that need to be timed in between 110 and 115degrees being better suited
the 7 port is meant to be a bit of a funny thing that likes monster cams.
In NA form it allegedly only really coms into its own with 296 or wilder cams.
eaton_mini
Member #: 1649
really..................oh crap!
Where did you find that out??? Its pretty much the last metal piece I need for the engine, Im hoping to order my megajolt soon so I dont have to faff around with a dizzy!
hearsay really,
eaton_mini
Member #: 1649
I was told to talk to swiftune, but he started by saying he wanted a grand to port my head to his cam etc...........er I dont think so!
Stuart gurr ported mine,
was about £350 with stuart suplying valves and springs etc
eaton_mini
Member #: 1649
Ive got someone to do the porting, I just really need to find a pro for sorting me out with the right camshaft. Minisport used one of their own, but Ive had one of those in a previous engine and the lobes fell off it!!!
Sam
Member #: 1686
Oxford
how lairy do you want to go.
if you cant put up with the cammy ness get a kent cams 266.
if you can put up with a little cammyness put in a 300 degree or more cam shaft.
eaton_mini
Member #: 1649
A little cammyness at 300 degrees, are you sure?!?!?! I would have thought that would make it lumpier than Tysons opponents after 12 rounds!!!!
Sam
Member #: 1686
Oxford
if you drop the idle to 1 grand when cold the ignition light flickers on and off. and will cut out sometimes.
mine idles at 2k when warm or 2300 with full choke when cold.
i love 649s, give one a try!
Sam
Member #: 1686
Oxford
not lairy enough for me joey :(
