| Home > Help Needed / General Tech Chat > Cutting out | |||||||
103 Posts Member #: 2314 Advanced Member cumbria |
24th Aug, 2008 at 08:27:45pm
Just a quick question. I coulnt find any similar problems on here from before. Just got car all together and running a week or so ago and have only drove it around the housing estate a few times but here goes.
1300 Posts Member #: 829 Post Whore essex |
24th Aug, 2008 at 08:54:41pm
check the ign feed to the coil is good 1293 Turbo mini
24th Aug, 2008 at 09:03:55pm
Do it do it when its hot or cold?
On 19th Jan, 2010 wil_h said:
24th Aug, 2008 at 09:52:13pm
with the rev counter going to zero i would be looking at power to coil, points conection to the coil or maybe even earthing points both in boot and engine bay Yes i moved to the darkside |
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
24th Aug, 2008 at 09:53:07pm
leads on the plugs/dizzy correctly?
eu gosto de mamas = i like boobs |
24th Aug, 2008 at 10:09:59pm
with the way the revo dies i would say that is pointing to the coil as well. |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
24th Aug, 2008 at 11:22:39pm
check it all then, check again! On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
25th Aug, 2008 at 12:08:13am
25th Aug, 2008 at 01:03:23am
Cheers for the replys. Come to think of it i would say your on the rite lines because when i tested for power at the coil before i initially started it i only got 9v betweem positive and negative but i got 12v between positive at the coil and the car body but when it started up no problem i thought nowt of it. I think il just try a temporary earth to the coil and see what happens. |
25th Aug, 2008 at 01:15:44am
that would mean you have 3v coming back down the earth side of the coil or is it too late for my brain to be working.
25th Aug, 2008 at 07:27:25am
On 25th Aug, 2008 turbogt said:
Cheers for the replys. Come to think of it i would say your on the rite lines because when i tested for power at the coil before i initially started it i only got 9v betweem positive and negative but i got 12v between positive at the coil and the car body but when it started up no problem i thought nowt of it. I think il just try a temporary earth to the coil and see what happens. What age/model car and which dizzy (points or electronic) ??? 8-9V is quite normal and correct on a car that has ballast ignition wiring and is meant for a ballast coil and points but is incompatible if you have fitted an engine with an electronic dizzy. Schrödinger's cat - so which one am I ??? |
25th Aug, 2008 at 11:02:53am
Is this using the mini rev counter?
25th Aug, 2008 at 11:47:22pm
Its the avonbar dizzy which is electronic. Its gotta be a bad connection because it runs beautifully when it dosent cut out. Could the standard 12v coil be to blame? Im gonna order a lucas gold coil for it tomorow allthough i plan on running coil pack set up eventually. |
