| Home > Help Needed / General Tech Chat > starting oil pressure problem | |||||||
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
25th Aug, 2008 at 06:39:24pm
when i start up my engine it takes about 5 to 8 seconds for oild pressure to get up after this oil pressure is fine, it kind of looks like the oil is draing back. o ring is in place as stuck it there with sealant. any thing you boys think i should check "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
25th Aug, 2008 at 06:44:30pm
Could it just be lag to the gauge if you know what I mean?
25th Aug, 2008 at 06:58:29pm
i have a oil pressure light but that is a 20 psi one so i might try a normal one but keep the ideas coming "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
25th Aug, 2008 at 07:02:23pm
do you have an oil cooler attached? are the pipes upside down or mounted at an angle, that can drain back into the sump. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
25th Aug, 2008 at 07:04:03pm
oil pump gasket?
25th Aug, 2008 at 07:15:48pm
25th Aug, 2008 at 08:18:41pm
Its worth checking out. I had to prime mine though everytime I started it.
On 25th Aug, 2008 Bat said:
Hi, I think Milamber had this problem on his metro. When he stripped it down he found a crack in the oil pump body... Cheers, Gavin :) Edited by Jason G on 25th Aug, 2008. On 19th Jan, 2010 wil_h said:
25th Aug, 2008 at 08:28:39pm
oil pump bolts go to 8ft/lb's.
25th Aug, 2008 at 08:55:56pm
On 25th Aug, 2008 richminiturbo. said:
oil pump bolts go to 8ft/lb's. Hope its something simple mate. i had this problem on my new build about a year ago, turned out to be bad gasket for oil filter, probably me over tightening it
Yes i moved to the darkside |
26th Aug, 2008 at 12:28:29pm
i had a very slight leak at the union on my guage, air would leak out until the oil 'sealed' it
26th Aug, 2008 at 06:11:35pm
think for the safe side i am going to look at the pump and gasket, so used to taking this thing appert it does not bother me any more, i had a feeling it was the pump and my hunches usually work out to be right, i have checked unions by the way before any one has a go at me for making this decision, all input was good input will let you now what it is "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
30th Aug, 2008 at 03:40:29pm
well got new power flow pump and did the cahange today and started her up and in a second i had oil pressure, oil pump is scrap as i found when i took the back plate off, will get pictures, gastket was fine. pump only done 2800 miles. "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
30th Aug, 2008 at 05:40:40pm
On 30th Aug, 2008 nogin said:
pump only done 2800 miles. was it from mini spares?, i have had a mini spares oil pump before and it never lasted 5 minutes
however i would like to say i have spent maybe £2000 with mini spares over the last 4 years and the pump is the only crap thing i have had from them Edited by Brett on 30th Aug, 2008. Yes i moved to the darkside |
30th Aug, 2008 at 05:52:35pm
the old power flow pump was from avonbar and the new one from mini spares, they are the same pump other then the back plate which i had a look at. the problem with the old one is that where the rotor sits in the back plate, it lloks like there has been no lubrication so has almost welded the back plate and the rotor together even though i primed the pump lots of times before fitting an starting so who nows what went on but all working sweet now, see how long this lasts if they have a bad rep "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
30th Aug, 2008 at 06:30:01pm
fit an extra long magnetic oil sump plug available from minispares this will help thing out
30th Aug, 2008 at 08:28:40pm
I thought all powerflow pumps from Avonbar & Minispares are the same. As Benross said, a dodgy pump. On 19th Jan, 2010 wil_h said:
31st Aug, 2008 at 08:13:40pm
there not the same look at the back plates, they are all the same bodies but the steel back plate is different "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
